查看: 5496|回复: 0
这种错误怎么改?
发表于 2009-5-4 11:21:53 | 显示全部楼层 |阅读模式
自己写的一段编码的程序:
  源码:
process(clk)
  begin
  if(clk'event and clk='1') then
         if(next_bit= '0')  then
            spdif <= not prev_spdif;
          else
            spdif <=  prev_spdif;
          end if;
        end if ;
       if(clk'event and clk='0') then
          else
            spdif<= not prev_spdif;
          end if;
        end if ;
   end process;
end rl;
报错:
     Error (10819): Netlist error at led.vhd(34): can't infer register for spdif because it changes value on both rising and falling edges of the clock
Error (10822): HDL error at led.vhd(27): couldn't implement registers for assignments on this clock edge
Error (10822): HDL error at led.vhd(34): couldn't implement registers for assignments on this clock edge
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 4 errors, 0 warnings
Info: Allocated 144 megabytes of memory during processing
Error: Processing ended: Mon Jan 01 03:02:29 2001
Error: Elapsed time: 00:00:35
GMT+8, 2025-12-26 10:42 , Processed in 0.019617 second(s), 6 queries , Gzip On, Redis On.
