楼主: windthunder
求助:两片FPGA之间实现简单通信怎么做?
发表于 2009-7-12 06:16:53 | 显示全部楼层
谢谢大家的热心回复,我正在努力 刚刚把75MHZ到100MHZ频率的转换编好,现在就准备设计一个简单的传输协议试一试
发表于 2009-7-12 08:25:21 | 显示全部楼层
具体内容具体分析
发表于 2009-7-15 21:55:32 | 显示全部楼层
entity myproject is
    Port ( clk75 : in  STD_LOGIC;
           testout : out  STD_LOGIC;
           clkout : out  STD_LOGIC);
end myproject;
architecture Behavioral of myproject is
signal clk75p:std_logic;
signal z:std_logic;
signal clkfb1:std_logic;
signal clk01:std_logic;
signal clk2x1:std_logic;
signal locked1:std_logic;
signal clkdv1:std_logic;
signal clk50p:std_logic;
signal clkfb2:std_logic;
signal clk02:std_logic;
signal clk2x2:std_logic;
signal locked2:std_logic;
signal clkdv2:std_logic;
signal clk100p:std_logic;
signal clkin2:std_logic;
component CLKDLLE
-- pragma translate_off
generic (
CLKDV_DIVIDE:string:real:=1.5;
DUTY_CYCLE_CORRECTION : boolean := TRUE;
STARTUP_WAIT : string : boolean := FALSE
-- pragma translate_on
port (CLKIN, CLKFB : in STD_LOGIC;
      CLK0, CLK90, CLK180, CLK270, CLK2X, CLKDV, LOCKED : out std_logic);
end component;
-- Attributes
attribute CLKDV_DIVIDE : string;
attribute DUTY_CYCLE_CORRECTION : string;
attribute STARTUP_WAIT : string;
attribute CLKDV_DIVIDE of CLKU1: label is "1.5";
attribute DUTY_CYCLE_CORRECTION of CLKU1: label is "TRUE";
attribute STARTUP_WAIT of CLKU1: label is "FALSE";
attribute CLKDV_DIVIDE of CLKU2: label is "3.0";
attribute DUTY_CYCLE_CORRECTION of CLKU2: label is "TRUE";
attribute STARTUP_WAIT of CLKU2: label is "FALSE";
component IBUFG
port (I : in STD_LOGIC; O : out std_logic);
end component;
component BUFG
end component;
begin
testout <= z;
clkout <= clk100p;
process(clk75p)
begin
if (clk75p 'event and clk75p='1') then
  z <= not z;
end if;
end process;
clk75ibuf: IBUFG
  port map (I => clk75,
            O => clk75p);
CLKU1: CLKDLLE
  port map (
       CLKIN => clk75p,
   CLKFB => clkfb1,
--   RST => reset_n,
   CLK0 => clk01,
   CLK2X => clk2x1,
   CLKDV => clkdv1,
   LOCKED=> locked1
CLKBU1: BUFG
  port map (
   I => clkdv1,
   O => clk50p
CLKBU2: BUFG
  port map (
   I => clk01,
   O => clkfb1
CLKU2: CLKDLLE
  port map (
       CLKIN => clk50p,
   CLKFB => clkfb2,
--     RST => reset_n,
       CLK0 => clk02,
   CLK2X => clk2x2,
   CLKDV => clkdv2,
   LOCKED=> locked2
CLKBU3: BUFG
  port map (
   I => clk2x2,
   O => clk100p
CLKBU4: BUFG
  port map (
   I => clk02,
   O => clkfb2
end Behavioral;
我编写的程序,不知道有没有太繁琐的地方,请高手帮我修改一下。还有我接下来要用100MHZ的时钟,是直接用clk100p就可以了吗?
发表于 2009-7-31 09:06:27 | 显示全部楼层
ttl or uart or i2c 都行。。。
发表于 2010-3-21 09:53:50 | 显示全部楼层
Oh, so many people from Taiwan? Why are they using complex Chinese characters?
GMT+8, 2025-12-30 20:37 , Processed in 0.268244 second(s), 3 queries , Gzip On, Redis On.
