查看: 2706|回复: 1
how to reduce power supply noise?
发表于 2009-4-24 19:01:33 | 显示全部楼层 |阅读模式
There is inducdance in bonding wire, if switch current in high speed, there will have large undershoot or overshoot
on power supply, I know that add decouping capacitor may help, but the cap needed may be large.
Anybody has experience to solve this problem?
发表于 2009-4-26 11:23:42 | 显示全部楼层
1. switch only after current become 0 by implementing minimum and maximum duty ratio
2. separate the power supply for different part of the IC so that the ringing will not cause malfunction to other part
GMT+8, 2025-12-23 22:45 , Processed in 0.020694 second(s), 6 queries , Gzip On, Redis On.
