楼主: clarkkevin
《2009 snug 第二名》 Advanced VMM Transactor Development Tips for Designing VIP
发表于 2016-4-28 00:44:57 | 显示全部楼层
thnx!
发表于 2016-4-30 15:35:04 | 显示全部楼层
thanks for sharing
发表于 2018-5-16 16:28:45 | 显示全部楼层
回复 1# clarkkevin
When the APB - I2C IP is programmed as the I2C slave interface, the APB controller polls the status
register to know whether a read or write is happening in the I2C interface. When a read or write is
completed the APB controller takes away the data from the FIFO by reading the data length registers and
address registers to map the register locations. This block throttles the data flow between the I2C interface
and the APB controller in slave mode
GMT+8, 2025-12-29 05:53 , Processed in 0.012265 second(s), 3 queries , Gzip On, Redis On.
