楼主: LasVegas
R.Jacob Baker: DRAM Circuit Design: Fundamental and High-Speed Topics
发表于 2013-11-5 02:01:50 | 显示全部楼层
Analog Designing
 the basics theorems of network systems
 Analysis of Second order systems (Peak overshoot, Settling time, damping factor etc)
 Stability analysis by the help of nyquist & bode plot
 Analysis of Z,Y,H & G Parameters in two port network
 Concepts of poles & zeros
 Miller theorem (very important)
 Diode & BJT characteristics
 MOS transfer characteristics, Small & large signal analysis.
 Basic CMOS inverter output vs input characteristics , region of operation & small signal analysis
 Small signal analysis of  various amplifiers ( common source, common Gate, Common Drain & cascode )
 differential Amplifiers ( small signal analysis & input vs output plot )
 current mirror
 Bandgap Reference, Regulator & V2I
 OPAMP, stability analysis of OPAMP, Miller compensation & Method to cancel positive zero
 Comparators
 Types of Noise
  Oscillator & Phase lock loop
  ADC & DAC ( at least theoretical analysis )
Analog Backend
 Analog Layouts techniques (Match transistors patterns, Match routing, shielding nets , resistors & capacitors layouts )
 latchup, electro migration, Hot electrons, Antenna Effects, OPC, Phase shift mask & CMP etc
 short channel effects in mosfets
 Worked on various simulators, layout editors & layout verification tools
 Worked on DRC,LVS,DFM,PERC,LFD & parasitic extraction flow
 Knowledge of scripting language like TCL, shell & awk commands
发表于 2013-11-5 03:06:53 | 显示全部楼层
收了~多谢楼主
发表于 2013-11-5 09:40:07 | 显示全部楼层
tks a lot
发表于 2015-3-31 18:53:37 | 显示全部楼层
only to page 377 !!!
发表于 2016-9-11 12:03:54 | 显示全部楼层
thanks!
发表于 2017-6-30 13:00:54 | 显示全部楼层
good!!!!!!!!!!!!!
发表于 2018-7-15 16:54:33 | 显示全部楼层
这个版本虽然有好多缺损,起码还有内容可以看
发表于 2023-7-7 19:25:19 | 显示全部楼层
thank you
发表于 2023-7-7 19:33:27 | 显示全部楼层
你这个费积分
发表于 2023-7-7 20:01:53 | 显示全部楼层
Thanks for sharing
GMT+8, 2025-12-30 11:28 , Processed in 0.018465 second(s), 3 queries , Gzip On, Redis On.
