楼主: cheng520so
【SI新书】Timing Analysis and Simulation for Signal Integrity Engineers
发表于 2013-8-9 03:29:58 | 显示全部楼层
Static timing analysis is a method of validating the timing performance of a design by checking all possible paths for timing violations. PrimeTime checks for violations in the same way that you would do it manually, but with much greater speed and accuracy.
To check a design for violations, PrimeTime breaks the design down into a set of timing paths, calculates the signal propagation delay along each path, and checks for violations of timing constraints inside the design and at the input/output interface.
Another way to perform timing analysis is to use dynamic simulation, which determines the
发表于 2013-8-9 03:38:29 | 显示全部楼层
PrimeTime SI (signal integrity) is a PrimeTime add-on feature that adds crosstalk analysis capabilities to PrimeTime static timing analyzer. PrimeTime SI calculates the timing effects of cross-coupled capacitors between nets and includes the resulting delay changes in the PrimeTime analysis reports. It also calculates the logic effects of crosstalk noise and reports conditions that could lead to functional failure. For more information, see the PrimeTime SI User Guide
发表于 2015-3-31 10:57:11 | 显示全部楼层
Timing Analysis and Simulation for Signal Integrity Engineers1.part01.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part02.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part03.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part04.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part05.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part06.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part07.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part08.rar (3.81 MB)
Timing Analysis and Simulation for Signal Integrity Engineers1.part09.rar (1.09 MB)
发表于 2015-3-31 10:57:52 | 显示全部楼层
发表于 2015-3-31 10:58:37 | 显示全部楼层
发表于 2015-3-31 10:59:54 | 显示全部楼层
发表于 2015-11-25 09:31:09 | 显示全部楼层
Thank you very much!!!
发表于 2016-5-3 17:34:32 | 显示全部楼层
发表于 2016-5-3 17:56:19 | 显示全部楼层
发表于 2016-5-3 17:59:10 | 显示全部楼层
GMT+8, 2025-12-25 15:50 , Processed in 0.017917 second(s), 3 queries , Gzip On, Redis On.
