楼主: cheng520so
【SI新书】Timing Analysis and Simulation for Signal Integrity Engineers
发表于 2013-1-22 16:10:40 | 显示全部楼层
回复 1# cheng520so
    谢谢楼主分享
发表于 2013-1-22 18:55:10 | 显示全部楼层
非常感谢。
发表于 2013-1-22 20:20:33 | 显示全部楼层
great book!
发表于 2013-2-17 00:00:50 | 显示全部楼层
好东西,必须顶啊。。。。。。
发表于 2013-5-12 02:38:36 | 显示全部楼层
very goooooood
发表于 2013-5-12 09:41:13 | 显示全部楼层
Thanks so much for sharing the book
发表于 2013-5-12 09:42:07 | 显示全部楼层
发表于 2013-6-19 16:31:52 | 显示全部楼层
zhemeda
发表于 2013-6-19 16:40:44 | 显示全部楼层
比较费钱
发表于 2013-8-9 03:20:13 | 显示全部楼层
Design Compiler Compatibility
The PrimeTime static timing analysis tool is designed to work well with the most commonly used synthesis tool, Design Compiler. PrimeTime and Design Compiler are compatible in the following ways:
•Both tools use the same technology libraries and read the same design data files in .db and .ddc formats.
•Both tools share many of the same commands, such as the create_clock, set_input_delay, and report_timing commands. Shared commands are identical or very similar in operation.
•Both tools share the same delay calculation algorithms and generally produce identical delay results.
•Timing reports generated by both tools are very similar.
•PrimeTime can capture the timing environment of a synthesizable subcircuit and write this timing environment as a series of Design Compiler commands. You can use the resulting script in Design Compiler to define the timing constraints for synthesis or logic optimization of the subcircuit.
•Both tools support the Synopsys Design Constraints (SDC) format for specifying design intent, including the timing and area constraints for a design.
Although Design Compiler has its own built-in static timing analysis capability, PrimeTime has better speed, capacity, and flexibility for static timing analysis, and offers many features not supported
GMT+8, 2025-12-25 12:15 , Processed in 0.018201 second(s), 4 queries , Gzip On, Redis On.
