楼主: xwlpxc
恳请大家分析下图:一个完整的带隙基准电路图中的一些问题交流请教
发表于 2010-8-2 16:55:19 | 显示全部楼层
MS2的W/L应该比较大,类似于一个小电阻
发表于 2011-1-15 14:49:30 | 显示全部楼层
回复 3# xiaxiaomingc1
    同感啊,貌似没联系,分析了好几遍都没找到启动电路如何启动的,启动电路倒是上电之后把自己关掉了,还存在那个倒比管的功耗呢。
发表于 2011-1-15 14:53:34 | 显示全部楼层
回复 33# luckyhuihui666
    结果是对的,但是说法好像错了,增大沟道长度,VTH不变吧。因该是增加等效沟道导通电阻吧。
发表于 2012-3-19 22:33:38 | 显示全部楼层
感觉无法启动啊,如果无法启动m5,那么启动电路根本就没有用
发表于 2012-3-19 23:44:40 | 显示全部楼层
启动电路?
发表于 2012-3-19 23:50:52 | 显示全部楼层
错误的启动设置
发表于 2012-3-20 09:22:53 | 显示全部楼层
Connect MS1 drain to Emitter of Q1 (minus input of OPAMP) so that start-up should work.
This can be best analyzed with 'control systems" "feedback circuit" perspective. Your circuit start-up does monitor BG start-up condition but does not control the BG's start-up operation. Start-up circuits input and output is the same point so it will likely oscillate around if BG  did not started by itself and loop has enogh gain. If BG started your start-up circuits observes that BG started (M5X will supply steady current and maintain voltage on R2X) and shuts off itself. Otherwise BG may or may not start by itself with no help from start-up circuit. SPICE may show BG starting so simulation result is not trust-able. Paper mentioned could also easily have a drawing error and even there is no drawing error researchers only pick started circuits and measure and publish results Leakages, dv/dt etc plays role in whether BG will start if start-up is not functioning. With this start-up, this BG circuit is not a reliable reference circuit and not commercially viable. Transistor sizes are not important for topologically wrong unreliable  un-manufacturable circuit.
Best Regards.  Good Luck.
发表于 2012-3-22 12:58:56 | 显示全部楼层
反比的 mos器件也是常用的
发表于 2012-5-11 23:24:41 | 显示全部楼层
看了上面的回帖,有一疑问,当电路不是自偏置时,自启动电路是否还有存在的必要?
发表于 2014-12-4 16:21:01 | 显示全部楼层
学习了
GMT+8, 2025-10-15 08:19 , Processed in 0.020146 second(s), 3 queries , Gzip On, Redis On.
