One of benefit of ac simulation using Spectre stb is the accurancy at high frequency region. It will consider the loading effect in your circuit, LC method, however, it doesn't. I also recomment use Spectre stb to do ac simulation
回复 34#microstudent Even select the high impedance node to do AC simulation through RC, the parasitic capacitance at that node at very high frequency still would affect the accuracy of the AC result
