LZ,我最近也做了一个LDO,也是要求很低的静态电流(10uA以内,including BGR),补偿方式也是传统的外接大电容,你说的奇怪情况我看了一下,没有发生,我在error OP 与pmos调整管间加了个buffer,可以将次级点与主极点的距离来开来保证稳定性。你可以试一下。buffer用电压跟随器或源级跟随器都行。
ac simulation is only for small signal. since ur biasing current is so small, most likely ur response is limited by nonlinearity effects such as slew rate limitation. this is why the ac and transient give you different results.
