查看: 4405|回复: 3
关于Ahuja compensation
发表于 2009-3-9 11:23:28 | 显示全部楼层 |阅读模式
手算的GBW有2.111G,实际仿真才563M
就是用gm/Cc算的,是忽略掉哪个重要电容了呢?
发表于 2009-3-9 14:37:33 | 显示全部楼层
1. check if any boosting  around fgbw
2. pole/zero simulation see where the pole and zero position
3. Ahuja has intrinsic pole and zero which are exactly cancelled if properly designed. However if not, and the pole split is not complete and usually generating complex pole makes your gm/Cc is must smaller
发表于 2009-4-23 14:20:39 | 显示全部楼层
请问楼主怎么联系,有qq号么?我想请教
发表于 2009-4-23 14:23:29 | 显示全部楼层
再顶一下!!~!
GMT+8, 2025-12-29 06:27 , Processed in 0.020750 second(s), 6 queries , Gzip On, Redis On.
