我想检查一下开发板io口的输入输出功能是否正常,应该如何做?
为何按照下面写的不太对?
我的思路是:
设置一个计数器,20位
将每一位输出到对应的io口
io口在作为输入
通过一个触发器保持这个值
想通过嵌入式逻辑分析器看看输出输入的波形
但综合后
作为输入的触发器没有没在逻辑分析器里面显示出来
应该如何写才正确?
`timescale 1ns / 1ps
module EP2S60F1020C5ES(
i_Clock,
i_Reset_n,
io_CON1_B,
io_CON1_C,
io_CON1_D,
io_CON1_E,
io_CON1_F,
io_CON2_B,
io_CON2_C,
io_CON2_D,
io_CON2_E,
io_CON2_F,
i_CON1_D2,
i_CON1_D3,
i_CON1_F18,
i_CON1_F19,
i_CON2_B10,
i_CON2_B11,
data
input i_Clock;
input i_Reset_n;
inout [19:0] io_CON1_B;
inout [19:0] io_CON1_C;
inout [19:0] io_CON1_D;
inout [19:0] io_CON1_E;
inout [19:0] io_CON1_F;
inout [19:0] io_CON2_B;
inout [19:0] io_CON2_C;
inout [19:0] io_CON2_D;
inout [19:0] io_CON2_E;
inout [19:0] io_CON2_F;
input i_CON1_D2;
input i_CON1_D3;
input i_CON1_F18;
input i_CON1_F19;
input i_CON2_B10;
input i_CON2_B11;
output data;
reg CNT_CON1_D2;
always @(posedge i_Clock or negedge i_Reset_n)
if(~i_Reset_n)
CNT_CON1_D2<=0;
else
CNT_CON1_D2<=i_CON1_D2;
reg [9:0] CNT;
if(~i_Reset_n)
CNT<=0;
else
CNT<=CNT+1;
assign io_CON1_B [0] =DAO_CON1_B0;
assign io_CON1_B [1] =DAO_CON1_B1;
assign io_CON1_B [2] =DAO_CON1_B2;
assign io_CON1_B [3] =DAO_CON1_B3;
assign io_CON1_B [4] =DAO_CON1_B4;
assign io_CON1_B [5] =DAO_CON1_B5;
assign io_CON1_B [6] =DAO_CON1_B6;
assign io_CON1_B [7] =DAO_CON1_B7;
assign io_CON1_B [8] =DAO_CON1_B8;
assign io_CON1_B [9] =DAO_CON1_B9;
assign io_CON1_B [10] =DAO_CON1_B10;
assign io_CON1_B [11] =DAO_CON1_B11;
assign io_CON1_B [12] =DAO_CON1_B12;
assign io_CON1_B [13] =DAO_CON1_B13;
assign io_CON1_B [14] =DAO_CON1_B14;
assign io_CON1_B [15] =DAO_CON1_B15;
assign io_CON1_B [16] =DAO_CON1_B16;
assign io_CON1_B [17] =DAO_CON1_B17;
assign io_CON1_B [18] =DAO_CON1_B18;
assign io_CON1_B [19] =DAO_CON1_B19;
assign CON1_B0 =io_CON1_B[0];
assign CON1_B1 =io_CON1_B[1];
assign CON1_B2 =io_CON1_B[2];
assign CON1_B3 =io_CON1_B[3];
assign CON1_B4 =io_CON1_B[4];
assign CON1_B5 =io_CON1_B[5];
assign CON1_B6 =io_CON1_B[6];
assign CON1_B7 =io_CON1_B[7];
assign CON1_B8 =io_CON1_B[8];
assign CON1_B9 =io_CON1_B[9];
assign CON1_B10 =io_CON1_B[10];
assign CON1_B11 =io_CON1_B[11];
assign CON1_B12 =io_CON1_B[12];
assign CON1_B13 =io_CON1_B[13];
assign CON1_B14 =io_CON1_B[14];
assign CON1_B15 =io_CON1_B[15];
assign CON1_B16 =io_CON1_B[16];
assign CON1_B17 =io_CON1_B[17];
assign CON1_B18 =io_CON1_B[18];
assign CON1_B19 =io_CON1_B[19];
reg DAO_CON1_B0;
reg DAO_CON1_B1;
reg DAO_CON1_B2;
reg DAO_CON1_B3;
reg DAO_CON1_B4;
reg DAO_CON1_B5;
reg DAO_CON1_B6;
reg DAO_CON1_B7;
reg DAO_CON1_B8;
reg DAO_CON1_B9;
reg DAO_CON1_B10;
reg DAO_CON1_B11;
reg DAO_CON1_B12;
reg DAO_CON1_B13;
reg DAO_CON1_B14;
reg DAO_CON1_B15;
reg DAO_CON1_B16;
reg DAO_CON1_B17;
reg DAO_CON1_B18;
reg DAO_CON1_B19;
reg DAI_CON1_B0;
reg DAI_CON1_B1;
reg DAI_CON1_B2;
reg DAI_CON1_B3;
reg DAI_CON1_B4;
reg DAI_CON1_B5;
reg DAI_CON1_B6;
reg DAI_CON1_B7;
reg DAI_CON1_B8;
reg DAI_CON1_B9;
reg DAI_CON1_B10;
reg DAI_CON1_B11;
reg DAI_CON1_B12;
reg DAI_CON1_B13;
reg DAI_CON1_B14;
reg DAI_CON1_B15;
reg DAI_CON1_B16;
reg DAI_CON1_B17;
reg DAI_CON1_B18;
reg DAI_CON1_B19;
if(~i_Reset_n)begin
DAO_CON1_B0 <=0;
DAO_CON1_B1 <=0;
DAO_CON1_B2 <=0;
DAO_CON1_B3 <=0;
DAO_CON1_B4 <=0;
DAO_CON1_B5 <=0;
DAO_CON1_B6 <=0;
DAO_CON1_B7 <=0;
DAO_CON1_B8 <=0;
DAO_CON1_B9 <=0;
DAO_CON1_B10 <=0;
DAO_CON1_B11 <=0;
DAO_CON1_B12 <=0;
DAO_CON1_B13 <=0;
DAO_CON1_B14 <=0;
DAO_CON1_B15 <=0;
DAO_CON1_B16 <=0;
DAO_CON1_B17 <=0;
DAO_CON1_B18 <=0;
DAO_CON1_B19 <=0;
end
else begin
DAO_CON1_B0 <=CNT[0];
DAO_CON1_B1 <=CNT[1];
DAO_CON1_B2 <=CNT[2];
DAO_CON1_B3 <=CNT[3];
DAO_CON1_B4 <=CNT[4];
DAO_CON1_B5 <=CNT[5];
DAO_CON1_B6 <=CNT[6];
DAO_CON1_B7 <=CNT[7];
DAO_CON1_B8 <=CNT[8];
DAO_CON1_B9 <=CNT[9];
DAO_CON1_B10 <=CNT[0];
DAO_CON1_B11 <=CNT[1];
DAO_CON1_B12 <=CNT[2];
DAO_CON1_B13 <=CNT[3];
DAO_CON1_B14 <=CNT[4];
DAO_CON1_B15 <=CNT[5];
DAO_CON1_B16 <=CNT[6];
DAO_CON1_B17 <=CNT[7];
DAO_CON1_B18 <=CNT[8];
DAO_CON1_B19 <=CNT[9];
end
if(~i_Reset_n)begin
DAI_CON1_B0 <=0;
DAI_CON1_B1 <=0;
DAI_CON1_B2 <=0;
DAI_CON1_B3 <=0;
DAI_CON1_B4 <=0;
DAI_CON1_B5 <=0;
DAI_CON1_B6 <=0;
DAI_CON1_B7 <=0;
DAI_CON1_B8 <=0;
DAI_CON1_B9 <=0;
DAI_CON1_B10 <=0;
DAI_CON1_B11 <=0;
DAI_CON1_B12 <=0;
DAI_CON1_B13 <=0;
DAI_CON1_B14 <=0;
DAI_CON1_B15 <=0;
DAI_CON1_B16 <=0;
DAI_CON1_B17 <=0;
DAI_CON1_B18 <=0;
DAI_CON1_B19 <=0;
end
else begin
DAI_CON1_B0 <=CON1_B0;
DAI_CON1_B1 <=CON1_B1;
DAI_CON1_B2 <=CON1_B2;
DAI_CON1_B3 <=CON1_B3;
DAI_CON1_B4 <=CON1_B4;
DAI_CON1_B5 <=CON1_B5;
DAI_CON1_B6 <=CON1_B6;
DAI_CON1_B7 <=CON1_B7;
DAI_CON1_B8 <=CON1_B8;
DAI_CON1_B9 <=CON1_B9;
DAI_CON1_B10 <=CON1_B10;
DAI_CON1_B11 <=CON1_B11;
DAI_CON1_B12 <=CON1_B12;
DAI_CON1_B13 <=CON1_B13;
DAI_CON1_B14 <=CON1_B14;
DAI_CON1_B15 <=CON1_B15;
DAI_CON1_B16 <=CON1_B16;
DAI_CON1_B17 <=CON1_B17;
DAI_CON1_B18 <=CON1_B18;
DAI_CON1_B19 <=CON1_B19;
end
endmodule |
