查看: 7013|回复: 3
opamp verilog-A model疑问
发表于 2009-3-2 13:34:08 | 显示全部楼层 |阅读模式
cadence中ahdlLib中opamp verilog-A代码最后两段,不是太明白
      // Output Stage.
      I(vref, vout) <+ V(cout, vref)/rout;
      I(vout, vref) <+ V(vout, vref)/rout;
无法想象出output stage到底是什么样一个结构?
      // Soft Output Limiting.
      if (V(vout) > (V(vspply_p) - vsoft))
         I(cout, vref) <+ gm_nom*(V(vout, vspply_p)+vsoft);
      else if (V(vout) < (V(vspply_n) + vsoft))
         I(cout, vref) <+ gm_nom*(V(vout, vspply_n)-vsoft);
   end
`include "discipline.h"
`include "constants.h"
// $Date: 1997/08/28 05:45:21 $
// $Revision: 1.1 $
// Based on the OVI Verilog-A Language Reference Manual, version 1.0 1996
`define PI   3.14159265358979323846264338327950288419716939937511
// opamp
// -  operational amplifier
// vin_p,vin_n: differential input voltage [V,A]
// vout: output voltage [V,A]
// vref: reference voltage [V,A]
// vspply_p: positive supply voltage [V,A]
// vspply_n: negative supply voltage [V,A]
// INSTANCE parameters
//    gain           = gain []
//    freq_unitygain = unity gain frequency [Hz]
//    rin            = input resistance [Ohms]
//    vin_offset     = input offset voltage referred to negative [V]
//    ibias          = input current [A]
//    iin_max           = maximum current [A]
//    slew_rate      = slew rate [A/F]
//    rout           = output resistance [Ohms]
//    vsoft          = soft output limiting value [V]
// MODEL parameters
//    {none}
module opamp(vout, vref, vin_p, vin_n, vspply_p, vspply_n);
input vref, vspply_p, vspply_n;
inout vout, vin_p, vin_n;
electrical vout, vref, vin_p, vin_n, vspply_p, vspply_n;
parameter real gain = 835e3;
parameter real freq_unitygain  = 1.0e6;
parameter real rin = 1e6;
parameter real vin_offset = 0.0;
parameter real ibias = 0.0;
parameter real iin_max = 100e-6;
parameter real slew_rate = 0.5e6;
parameter real rout = 80;
parameter real vsoft = 0.5;
   real c1;
   real gm_nom;
   real r1;
   real vmax_in;
   real vin_val;
   electrical cout;
   analog begin
      @ ( initial_step or initial_step("dc") ) begin
  c1 = iin_max/(slew_rate);
  gm_nom = 2 * `PI * freq_unitygain * c1;
  r1 = gain/gm_nom;
  vmax_in = iin_max/gm_nom;
      end
      vin_val = V(vin_p,vin_n) + vin_offset;
      // Input stage.
      I(vin_p, vin_n) <+ (V(vin_p, vin_n) + vin_offset)/ rin;
      I(vref, vin_p) <+ ibias;
      I(vref, vin_n) <+ ibias;
      // GM stage with slewing
      I(vref, cout) <+ V(vref, cout)/100e6;
      if (vin_val > vmax_in)
         I(vref, cout) <+ iin_max;
      else if (vin_val < -vmax_in)
         I(vref, cout) <+ -iin_max;
      else
         I(vref, cout) <+ gm_nom*vin_val ;
      // Dominant Pole.
      I(cout, vref) <+ ddt(c1*V(cout, vref));
      I(cout, vref) <+ V(cout, vref)/r1;
      // Output Stage.
   end
endmodule
发表于 2010-10-19 22:30:16 | 显示全部楼层
回复 1# seamasc
    同问,哪位来帮忙解答下。
发表于 2010-10-19 23:24:17 | 显示全部楼层
搭车同问。。。
发表于 2016-3-4 19:05:35 | 显示全部楼层
是一个gain为1的buffer,用来防止输出负载对运放gain的影响。
GMT+8, 2025-12-26 02:49 , Processed in 0.017664 second(s), 5 queries , Gzip On, Redis On.
