查看: 18744|回复: 52
最新IC核心期刊IEEE JSSC 2009年3月份大热卖,做RF的过来看看了!
发表于 2009-2-27 09:50:35 | 显示全部楼层 |阅读模式
JSSC的3月份主要是做RF的,展示了业界的最新成果,有兴趣的不要错过。所有的附件都是按照标号的顺序来的,对照着下载就可以。
1          32 mW 1.25 GSs 6b 2bStep SAR ADC in 0.13$ mu$m CMOS
2          256-Channel Neural Recording and Delta Compression Microsystem With 3D Electrodes
3          A 0.8 V, 2.6 mW, 88 dB Dual-Channel Audio Delta-Sigma DA Converter With Headphone Driver
4          A 1.2 GSample per s Double-Switching CMOS THA With ${- }$62 dB THD
5          A 1.2 V 114 mW Dual-Band Direct-Conversion DVB-H Tuner in 0.13 $mu$ m CMOS
6          A 2.2 mW 1.75 GSs 5 Bit Folding Flash ADC in 90 nm Digital CMOS
7          A 2.4–2.5 GHz WLAN Direct-Conversion Receiver Front-End With Low-Distortion Baseband Filters
8          A 2.7 mW, 90.3 dB DR Continuous-Time Quadrature Bandpass Sigma-Delta Modulator for GSM EDGE Low-IF Receiver in 0.25 $mu$m CMOS
9          A 3 GHz Fractional All-Digital PLL With a 1.8 MHz Bandwidth Implementing Spur Reduction Techniques
10        A 4.8 GSs 5-bit ADC-Based Receiver With Embedded DFE for Signal Equalization
32 mW 1.25 GSs 6b 2bStep SAR ADC in 0.13$ mu$m CMOS.pdf (2.04 MB , 下载次数: 83 )
256-Channel Neural Recording and Delta Compression Microsystem With 3D Electrodes.pdf (1.57 MB , 下载次数: 46 )
abbr_5efa4156ed915a40cab04ddd98d6d605.pdf (1.66 MB , 下载次数: 66 )
A 1.2 GSample per s Double-Switching CMOS THA With ${- } dB THD.pdf (3.19 MB , 下载次数: 63 )
A 1.2 V 114 mW Dual-Band Direct-Conversion DVB-H Tuner in 0.13 $mu$ m CMOS.pdf (2.6 MB , 下载次数: 79 )
A 2.2 mW 1.75 GSs 5 Bit Folding Flash ADC in 90 nm Digital CMOS.pdf (1.27 MB , 下载次数: 63 )
abbr_4bc90d306fb2692258e1861e6fdbe46b.pdf (503.49 KB , 下载次数: 67 )
abbr_6b4bade8cbe739ce487fdc104a20e0d5.pdf (1.39 MB , 下载次数: 94 )
abbr_53d313f21f40cc2ca25b885915ce0c9a.pdf (1.93 MB , 下载次数: 62 )
A 4.8 GSs 5-bit ADC-Based Receiver With Embedded DFE for Signal Equalization.pdf (1.61 MB , 下载次数: 66 )
[ 本帖最后由 corespirit36 于 2009-2-27 10:00 编辑 ]
 楼主| 发表于 2009-2-27 09:55:41 | 显示全部楼层
11  A 10-bit 50 MSs Pipelined ADC With Capacitor-Sharing and Variable-$g_{m}$ Opamp
12  A 33.6-to-33.8 Gbs Burst-Mode CDR in 90 nm CMOS Technology
13  A 60 kbs–10 Mbs Adaptive Frequency Hopping Transceiver for Interference-Resilient Body Channel Communication
14  A 125–1250 MHz Process-Independent Adaptive Bandwidth Spread Spectrum Clock Generator With Digital Controlled Self-Calibration
15  A Biomimetic, 4.5uW, 120+ dB, Log-Domain Cochlea Channel With AGC
16  A High-Speed Inductive-Coupling Link With Burst Transmission
17  A New Transceiver Architecture for the 60-GHz Band
18  A Process Variation Tolerant Embedded Split-Gate Flash Memory Using Pre-Stable Current Sensing Scheme
19  A Single–Chip 10-Band WCDMA or HSDPA 4-Band GSM or EDGE SAW-less CMOS Receiver With DigRF 3G Interface and +90dBm IIP2
20  A Wideband CMOS Low Noise Amplifier Employing Noise and IM2 Distortion Cancellation for a Digital TV Tuner
A 10-bit 50 MSs Pipelined ADC With Capacitor-Sharing and Variable-$g_{m}$ Opamp.pdf (696.81 KB , 下载次数: 72 )
A 33.6-to-33.8 Gbs Burst-Mode CDR in 90 nm CMOS Technology.pdf (1.17 MB , 下载次数: 54 )
abbr_9cef8f146d5a7dc1e17b916351afc967.pdf (2.34 MB , 下载次数: 36 )
abbr_5887f112ef0a038b8555ac5dcb384080.pdf (3.33 MB , 下载次数: 72 )
A Biomimetic, 4.5uW, 120+ dB, Log-Domain Cochlea Channel With AGC.pdf (1.25 MB , 下载次数: 48 )
A High-Speed Inductive-Coupling Link With Burst Transmission.pdf (1.38 MB , 下载次数: 34 )
A New Transceiver Architecture for the 60-GHz Band.pdf (1.37 MB , 下载次数: 60 )
abbr_ff027b2eb57452d58797d3cc68a43d4f.pdf (1.61 MB , 下载次数: 37 )
abbr_53d63c8c2fe28d91c1273cd0bd66b0b4.pdf (2.02 MB , 下载次数: 57 )
abbr_0b314cca8fbc16863ac6443fed4eab2c.pdf (959.15 KB , 下载次数: 55 )
 楼主| 发表于 2009-2-27 09:59:24 | 显示全部楼层
21  An LC-Based Clock Buffer With Tunable Injection Locking
22  Analysis and Design of a CMOS Phase-Tunable Injection-Coupled LC Quadrature VCO (PTIC-QVCO)
23  Design of Power-Rail ESD Clamp Circuit With Ultra-Low Standby Leakage Current in Nanoscale CMOS Technology
24  Design of Sub-90 nm Low-Power and Variation Tolerant PD or SOI SRAM Cell Based on Dynamic Stability Metrics
25  Distributed Waveform Generator- A New Circuit Technique for Ultra-Wideband Pulse Generation, Shaping and Modulation
26  Laser Radar Receiver Channel With Timing Detector Based on Front End Unipolar-to-Bipolar Pulse Shaping
27  Low-Power Race-Free Programmable Logic Arrays
28  Multi-Standard Mobile Broadcast Receiver LNA With Integrated Selectivity and Novel Wideband Impedance Matching Technique
29  Output Impedance Shaping for Frequency Compensation of MOS Audio Power Amplifiers
30  Synchronous Ultra-High-Density 2RW Dual-Port 8T-SRAM With Circumvention of Simultaneous Common-Row-Access
An LC-Based Clock Buffer With Tunable Injection Locking.pdf (1.37 MB , 下载次数: 45 )
abbr_d14b50dcb9fcdcddf757e54892bb65c5.pdf (773.49 KB , 下载次数: 56 )
abbr_631658efcd5f8c109cf217146fb4ad96.pdf (1.22 MB , 下载次数: 40 )
abbr_173a102b0a4623e3e5087750536c9bea.pdf (2.11 MB , 下载次数: 35 )
abbr_b994fc9a96187dac7e6673efd9b0e686.pdf (2.27 MB , 下载次数: 38 )
abbr_739598f1f5314956ccc8d1f06afa6123.pdf (1.42 MB , 下载次数: 37 )
Low-Power Race-Free Programmable Logic Arrays.pdf (2.25 MB , 下载次数: 29 )
abbr_b24b8495fdf95650fa8c92954af00859.pdf (1.17 MB , 下载次数: 51 )
Output Impedance Shaping for Frequency Compensation of MOS Audio Power Amplifiers.pdf (856.95 KB , 下载次数: 36 )
abbr_7ec3edb6a7b2d389216cf9dd3b482ada.pdf (2.73 MB , 下载次数: 45 )
发表于 2009-2-27 10:05:51 | 显示全部楼层
小伙儿你费心了
 楼主| 发表于 2009-2-27 11:23:17 | 显示全部楼层
发表于 2009-2-27 12:56:28 | 显示全部楼层
号东西,谢谢!
发表于 2009-2-27 13:25:31 | 显示全部楼层
谢谢楼主!
什么时候楼主把JSSC 08年12月份的传上来啊?期待。。。。
 楼主| 发表于 2009-2-27 18:53:25 | 显示全部楼层
发表于 2009-2-27 20:02:39 | 显示全部楼层
xiexie
发表于 2009-2-27 20:18:13 | 显示全部楼层
GMT+8, 2025-12-28 02:29 , Processed in 0.082295 second(s), 7 queries , Gzip On, Redis On.
