查看: 4839|回复: 11
弱问一个简单的问题
发表于 2009-2-23 16:07:55 | 显示全部楼层 |阅读模式
最近正在学习Verilog,想问一下为什么{random}%60产生的是0~59之间的数
也就是random加拼接运算符后产生的值就略去了负的部分呢?
期望有人解答,谢谢!~!~!~!
发表于 2009-2-23 17:40:20 | 显示全部楼层
You ask a very good question.
According IEEE 1364-2005 page 341:
The system function $random provides a mechanism for generating random numbers. The function returns
a new 32-bit random number each time it is called. The random number is a signed integer; it can be positive
or negative. For further information on probabilistic random number generators, see 17.9.2.
The seed argument controls the numbers that $random returns so that different seeds generate different
random streams. The seed argument shall be either a reg, an integer, or a time variable. The seed value
should be assigned to this variable prior to calling $random.
For example:
Example 1—Where b is greater than 0, the expression ($random % b) gives a number in the following
range: [(-b+1): (b-1)].
So I think your assumption is wrong.
 楼主| 发表于 2009-2-23 18:27:27 | 显示全部楼层
我是看到夏宇闻老师书上他是这么写的,因为我不是很明白,所以才问的。
发表于 2009-2-23 19:11:20 | 显示全部楼层
很简单,说明书错了:)
发表于 2009-2-23 21:33:30 | 显示全部楼层
好好干,你能成为一个优秀的工程师的.
[ 本帖最后由 humann 于 2009-2-24 03:09 编辑 ]
发表于 2009-2-23 21:51:13 | 显示全部楼层
夏宇闻 is right. I make a mistake.
The {} treats all parameter as unsigned  value and so products an  unsigned value too.
You can run the following test program in simulator.
You can try to remove {} to watch the different effect.
// test program
module top;
   initial       repeat(80) #1 $display("%d ($random) mod 60  ->  %d", $random, {$random}%60);
   initial       #100 $finish;
endmodule
头像被屏蔽
发表于 2009-2-24 09:33:47 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-2-24 10:46:26 | 显示全部楼层
我的理解也是,{random}%相当于对正数的求%,
发表于 2009-2-24 15:50:00 | 显示全部楼层
对这个系统函数,我还没有用过。不过现在学到了一些新的知识了。
发表于 2009-2-24 19:38:26 | 显示全部楼层
恩,不错的问题
GMT+8, 2025-12-29 09:03 , Processed in 0.109264 second(s), 9 queries , Gzip On, Redis On.
