查看: 6016|回复: 0
ATPG warning help
发表于 2009-2-19 19:06:19 | 显示全部楼层 |阅读模式
大家好, 我在用Encounter Test 做ATPG的时候 , tool 报了一堆的Warning , 然后生成的Pattern Fault coverage 只有 8% , ,我截取了其中的一个,  请大家帮忙分析一下原因,谢谢 !
#####  part of Log
Clock input pin u_zip_reg.IO.dff_primitive.master.PO2DCLK on memory element block u_zip_reg.IO.dff_primitive.master.PO2DCLK is OFF (at logic zero) when in the Test Inhibit state.
Clock input pin u_zip_reg.IO.dff_primitive.slave.PO2DCLK on memory element block u_zip_reg.IO.dff_primitive.slave.PO2DCLK is OFF (at logic zero) when in the Test Inhibit state.
##### pin assignment file
assign pin=RESN_pad                  test_function= +TI;     # global reset pad
assign pin=TMOD_pad                 test_function= 1TI;     # test mode
assign pin=XTAL_pad                   test_function= -ES;    # test clock && sys clock
assign pin=SCAN_ENABLE_pad   test_function= +SE;   # scan enable
assign pin=SCAN_IN_pad             test_function= SI;       # scan input
assign pin=SCAN_OUT_pad         test_function= SO;     # scan output
##### part of netlist
BUF4         u0( .A(RESN_pad), .Y(resn_in) );
CLKBUF4  u1( .A(XTAL_pad), .Y(sys_clk) );
AND2X4     u2( .B(TMOD_pad), .A(XTAL_pad), .Y(test_clock) );
MUX2X       u3( .SO(TMOD_pad), .B(test_clock), .A(sys_clk), .Y(sysCLK_scan) );
AND2X4     u4( .B(SCAN_ENABLE_pad), .A(TMOD_pad), .Y(SCAN_sen) );
SDFFSQx  u_zip_reg( .SN(resn_in), .CK(sysCLK_scan), .D(n_4306), .SI(n_7828), .SE(SCAN_sen), .Q(n_2708) );
GMT+8, 2025-12-26 02:40 , Processed in 0.017919 second(s), 6 queries , Gzip On, Redis On.
