发表于 2009-10-13 18:10:24
显示全部楼层
建议:在做dc analysis时
dc > Save DC Operating Point > Netlist and Run
After finisih the DC analysis, in Virtuso Analog Design Environment
Results > Print > DC operating points, 此时会弹出Results Display Window, 然后点击想看的device,如mos transistor, resistor and so on。这些device 的直流特性将会出现在Results Display Window里,非常容易查看,这样就不用为“显示的是小数点后面13位小数,太多了”而发愁了。 |
