查看: 5409|回复: 3
[新品介绍] ModelSim SE PLUS 5.8b is released
发表于 2004-2-12 11:05:25 | 显示全部楼层 |阅读模式
:em02:
 楼主| 发表于 2004-2-12 11:05:58 | 显示全部楼层
:em09:
 楼主| 发表于 2004-2-12 11:08:48 | 显示全部楼层
New Features Added to 5.8b
     * A new subcommand for find has been added. find instances will find
       instances  in  the  current region which match the search pattern.
       The usage is:
       find instances [-r] <pattern>
     * vsim -restore is now allowed in GUI mode.
     * The   vlog  switch  -instantiateReadOnly  allows  Verilog  modules
       compiled  with  -fast  to instantiate modules or UDPs from library
       directories  which  have  read-only permission. The instantiations
       will not be inlined or further optimized.
     * The  vsim option +delayed_timing_checks causes timing checks to be
       performed  on  the  delayed  versions of input ports. This is used
       when there are negative timing check limits.
     * VHDL configurations now support loading Verilog configurations and
       vice versa.
发表于 2007-9-10 00:18:32 | 显示全部楼层
good one
GMT+8, 2025-11-20 23:20 , Processed in 0.022267 second(s), 6 queries , Gzip On, Redis On.
