楼主: semico_ljj
请教:Native MOS 有什么优势,主要用在哪里?谢谢!
发表于 2010-4-8 22:16:16 | 显示全部楼层
understanding, thanks
发表于 2010-4-14 22:37:59 | 显示全部楼层
开关电路中会用到
发表于 2010-4-15 17:16:01 | 显示全部楼层
这东西有什么坏处吗?
看工艺库中它的model都比较简单。
发表于 2010-6-3 10:21:38 | 显示全部楼层
native mos for short channel也要注意漏電
发表于 2010-6-18 10:46:07 | 显示全部楼层
同问,如果native NMOS和普通NMOS的注入浓度不同,那么工艺上是如何实现的呢?只用一层mask就可以实现两种不同的注入浓度?而且大部分foundry提供的SPICE model里面都没有关于native MOS的描述哦。
发表于 2010-8-24 13:20:48 | 显示全部楼层
wiki
須要多mask doping
且 native mos 比一般大
native NMOS gate is 2-3 times longer and wider than standard Threshold voltage transistor.
someone said GM is Low
发表于 2010-8-24 15:03:36 | 显示全部楼层
foxzciori 发表于 2010-6-18 10:46
Native NMOS does not need extra mask. It share same N/P+ source/drain implantion directly on p-substrate, without well implantation.
TSMC all provide native NMOS spice model in its logic/MM process.
发表于 2010-8-24 17:10:22 | 显示全部楼层
I think it should be the source follower, there is less voltage drop between Vgs because of its smaller Vth.
piao 发表于 2009-1-4 22:51
同意
发表于 2010-8-24 17:15:37 | 显示全部楼层
27# littlej
smic18库中也有,用过不需要额外加mask
发表于 2011-2-25 20:37:11 | 显示全部楼层
可以用作MOS电容
GMT+8, 2025-12-29 02:17 , Processed in 0.018718 second(s), 3 queries , Gzip On, Redis On.
