楼主: xiangzi23456
Cadence IC610(CDROM1,共5张)
发表于 2009-5-25 16:17:51 | 显示全部楼层
Thanks a lot for capturing ic610
发表于 2009-5-25 16:41:37 | 显示全部楼层
Downloading is a hard work.
发表于 2009-5-25 17:33:48 | 显示全部楼层
Linux pthread is used in ic5033 and ic5141, so that the environment variable LD_ASSUME_KERNEL=2.4.0 should be exported at RHEL3 & 4
发表于 2009-5-25 17:43:34 | 显示全部楼层
  ic433 -> ic5033 -> ic5141 -> ic610-> ?
发表于 2009-5-25 17:50:34 | 显示全部楼层
I appreciate for capturing ic610
发表于 2009-5-25 17:52:09 | 显示全部楼层
ldv51 -> ius5.4 -> ?
发表于 2009-5-25 18:12:02 | 显示全部楼层
Thanks for ic610
发表于 2009-5-25 18:14:59 | 显示全部楼层
My task now is designing an asynchronous sram
发表于 2009-5-25 19:08:55 | 显示全部楼层
thanks
发表于 2009-5-26 09:48:39 | 显示全部楼层
I try to download again
GMT+8, 2025-12-24 04:05 , Processed in 0.018390 second(s), 3 queries , Gzip On, Redis On.
