楼主: duling653
Cadence Spectre有没有官方的帮助文档啊
 楼主| 发表于 2008-12-30 13:21:42 | 显示全部楼层
错误提示里面写的是:
The web browser can't be started. On UNIX, make sure that your PATH environment variable includes the path to Netscape. On Windows/NT,
make sure that either internet Explorer 5.0 (or higer) or Netscape 4.51 (or higher) is installed with standard registry entries.
发表于 2008-12-30 18:47:46 | 显示全部楼层
铜球
铜球铜球铜球铜球铜球铜球铜球
发表于 2008-12-31 10:39:59 | 显示全部楼层
ddddddddddddddddddddd
发表于 2009-2-24 19:52:06 | 显示全部楼层
谢谢诶楼主
发表于 2009-2-26 09:47:13 | 显示全部楼层
不错啊 ,还是挺好的
发表于 2009-2-27 20:52:42 | 显示全部楼层
正学习呢,谢谢;饿
发表于 2009-2-28 19:37:08 | 显示全部楼层
看看
发表于 2009-3-19 16:36:28 | 显示全部楼层
Please read this post at
http://www.asiaa.sinica.edu.tw/~ctli/IC5141/How%20to%20install%20Cadence%20IC5_0_33%20under%20Linux%20RedHat9.htm
You can create link:
ln -s             /usr/bin/mozilla /usr/bin/netscape
After it add line to your             .cshrc file:
setenv MOZILLA_HOME /usr/bin/netscape
I tried, and it works.
发表于 2009-3-19 21:04:24 | 显示全部楼层
谢谢了 先收下
发表于 2009-3-22 20:44:24 | 显示全部楼层
对呀,就cdsdoc里就可以找到一些,或者到cadence的网站上sourceLink搜一下,不过要账号的
GMT+8, 2025-10-24 13:45 , Processed in 0.018106 second(s), 5 queries , Gzip On, Redis On.
