查看: 2859|回复: 7
MOS Matlab Models
发表于 2008-10-9 14:30:09 | 显示全部楼层 |阅读模式
A set of matlab (©) models that capture the basic equations for transistors and inverters. The model archive contains the following functions:
Transistor static models
mos(W, L, vgs, vds, vsb, technology): captures the unified DSM MOS model as introduced in the text
technology is a vector with 8 elements [type vt0 gamma beta lambda vdsat ld wd] (type is 1 for NMOS, -1 for PMOS)
threshold(vsb, type, vt0, gamma): computes the actual threshold of the transistor as a function of the body bias
nmos025(W, L, vgs, vds, vsb) and pmos025(W, L, vgs, vds, vsb): compute the MOS model for the 0.25 micron CMOS technology used in the text
nmos025id and pmos025id: plots the id(vds) curves for the 0.25 micron transistors. A 2.5 V range of voltages is assumed.
nmos025vgs: generate the id(vgs) curves for the 0.25 micron transistors. A 2.5 V range of voltages is assumed.
Transistor capacitive models
gatecap(W,L,ctech, region): computes the gate cap and its distribution dependent upon the operation regaion. region is the operational region of the transistor (cutoff=0, linear=1 or sat=2). ctech is an 8 element vector containing the essential technology parameters needed to compute the capacitances: [tox, cov, cj, mj, pb, cjsw, mjsw, pbsw]
junctioncap(vb, cj0, m, phi): computes the junction cap as a function of the bias voltage
moscap(W, L, vgs, vds, vsb, tech, ctech): generates a vector containing the 5 transistor capacitances
[cgs cgd cgb cdb csb].
tech and ctech are the transistor and capacitance technology vectors respectively.
nmos025cap(W, L, vgs, vds, vsb) and pmos025cap(W, L, vgs, vds, vsb): compute the capacitances of 0.25 micron NMOS and PMOS transistors
keq(vb, m, phi): computes the linearizing keq factor as a function of the voltage range
Inverter models
inverter_vtc(vdd, wn, ln, wp, lp): Plots the voltage transfer characteristic of an inverter as a function of supply voltage and transistor dimensions. WARNING: This functions takes some compute time!
inverter_threshold(vdd, wn, ln, wp, lp): computes the inverter threshold as a function of the transistor dimensions
inverter_gain(vdd, wn, ln, wp, lp): computes the gain at VM. It returns two values, one obtained from the simple equation in the book, the second one taking the channel-length modulation into account.
mos_matlab_models.rar
5.39 KB, 下载次数: 32 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-11 14:54:07 | 显示全部楼层
kankan!!!!
发表于 2008-10-21 21:31:21 | 显示全部楼层
看看,
发表于 2008-11-20 23:48:07 | 显示全部楼层
看了一下感觉用处不大,要模拟直接用hspice即可
发表于 2008-11-24 20:41:02 | 显示全部楼层
原來還有這個
感謝你的分享
发表于 2009-2-3 21:08:03 | 显示全部楼层
看看好了  = =
发表于 2010-4-20 11:01:26 | 显示全部楼层
谢谢楼主哈!
发表于 2011-1-6 16:58:01 | 显示全部楼层
谢谢~~
GMT+8, 2025-12-30 10:55 , Processed in 0.020399 second(s), 6 queries , Gzip On, Redis On.
