查看: 3309|回复: 14
2006Newnes-Cellular Communications Explained: From Basics to 3G
发表于 2008-10-8 10:32:18 | 显示全部楼层 |阅读模式
[size=120%]Cellular Communications Explained: From Basics to 3G
By Ian Poole
Publisher:   Newnes
Number Of Pages:   216
Publication Date:   2006-03-17
ISBN-10 / ASIN:   0750664355
ISBN-13 / EAN:   9780750664356
Binding:   Paperback
Product Description:
Among the many books published on 3G and cellular telecommunications, this introduction stands out due to its broad coverage of the subject and straightforward explanations of the principles and applications using a minimum of maths. Writing as an engineer for engineers, Ian Poole provides a systems-level view of the fundamentals that will enhance the understanding of engineers involved working in this fast-paced field. Equally, the book helps students, technicians and equipment manufacturers to gain a working knowledge of the applications and technologies involved in cellular communications equipment and networks.
The book focuses on the latest 2G, 2.5G and 3G technologies, including GSM (with GPRS and EDGE), NA-TDMA, cdmaOne (IS-95), CDMA2000 and UMTS (W-CDMA), with material on developing areas such as HSDPA. The fundamentals of radio propagation, modulation and cellular basics are also covered in a way that will give readers a real grasp of how cellular communications systems and equipment work.
* Explains the principles and applications of cellular communications systems using a minimum of mathematics, providing a firm grounding for engineers, technicians and students.
* Covers current technologies (2G, 2.5G) alongside 3G and other cutting-edge technologies, making this essential reading, not crystal ball gazing!
* Provides coverage of fundamentals and whole systems, as well as equipment provides a wide knowledge base for engineers and technicians working in different parts of the industry: handset designers, network planners, maintenance technicians, technical sales, etc.
[ 本帖最后由 woainio 于 2008-10-8 10:35 编辑 ]
0750664355.zip
1.06 MB, 下载次数: 68 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-8 21:00:38 | 显示全部楼层
sdfg sdgsdf sdfgs dgsdfg sdfg s
发表于 2008-10-8 21:02:23 | 显示全部楼层
Designing High-Speed Interconnect Circuits.pdf
发表于 2008-10-8 21:10:44 | 显示全部楼层
sdfg sddfsd sdtd ftydft dty
发表于 2008-10-8 21:13:45 | 显示全部楼层
asdf asdfasdfa sdfa sda
发表于 2008-10-8 21:22:28 | 显示全部楼层
ENGINEERING
发表于 2008-10-8 21:25:59 | 显示全部楼层
ENGINEERING
发表于 2008-10-8 22:19:06 | 显示全部楼层
interesting book, thanks.
发表于 2008-10-9 08:02:03 | 显示全部楼层
了解一下
发表于 2008-10-11 12:42:47 | 显示全部楼层
谢谢楼主,下来参考参考!!!!!!!!!!!!!!!
GMT+8, 2025-12-16 15:19 , Processed in 0.030083 second(s), 8 queries , Gzip On, Redis On.
