查看: 8532|回复: 30
DESIGN OF SNUBBERS FOR POWER CIRCUITS
发表于 2008-10-6 15:13:19 | 显示全部楼层 |阅读模式
The author Rudy Severns's selection for Power Electronics Technology (PET) Magazine's prestigious Lifetime Achievement Award was announced in their September 2008 issue.
http://powerelectronics.com/power_systems/rudy_severns_lifetime_achievement_award-809/
What’s a snubber?
Power semiconductors are the heart of power electronics equipment. Snubbers are circuits whichare placed across semiconductor devices for protection and to improve performance. Snubbers can domany things:
·Reduce or eliminate voltage or current spikes·Limit dI/dt or dV/dt
·Shape the load line to keep it within the safe operating area (SOA)
·Transfer power dissipation from the switch to a resistor or a useful load
·Reduce total losses due to switching
·Reduce EMI by damping voltage and current ringing
There are many different kinds of snubbers but the two most common ones are the resistor-capacitor (RC) damping network and the resistor-capacitor-diode (RCD) turn-off snubber. This appli-cation note will show you how to design these two snubbers.
DESIGN OF SNUBBERS FOR POWER CIRCUITS.pdf
250.26 KB, 下载次数: 157 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-10-6 15:19:06 | 显示全部楼层
Snubber Circuits:Theory , Design and Application by Philip C. Todd
Introduction
Snubbers are an essential part of power electronics.
Snubbers are small networks of parts in the
power switching circuits whose function is to
control the effects of circuit reactances.
Snubbers enhance the performance of the switching
circuits and result in higher reliability, higher
efficiency, higher switching frequency, smaller size,
lower weight, and lower EMI. The basic intent of
a snubber is to absorb energy from the reactive
elements in the circuit. The benefits of this may
include circuit damping, controlling the rate of
change of voltage or current, or clamping voltage
overshoot. In performing these functions a snubber
limits the amount of stress which the switch must
endure and this increases the reliability of the
switch. When a snubber is properly designed and
implemented the switch will have lower average
power dissipation, much lower peak power dissipation,
lower peak operating voltage and lower peak
operating current. This article describes some of the
various types of snubbers, where they are used,
how they function, how they are designed and what
their limitations are.
Snubbers may be either passive or active networks.
This article is limited to the main types of passive
snubbers. Passive snubber network elements are
limited to resistors, capacitors, inductors and diodes.
Active snubbers include transistors or other active
switches, often entail a significant amount of extra
circuitry and introduce another level of parasitics
which must be dealt with (usually with a passive
snubber). However, active snubbers are appropriate
in some applications. A good example of an active
snub is what you would like to say to your boss
when he or she decides not to give you a raise.
snubbers.pdf
1.93 MB, 下载次数: 120 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-6 19:59:56 | 显示全部楼层
thank you
发表于 2009-5-4 20:51:04 | 显示全部楼层
Good sharing!
3Q!
发表于 2009-5-4 21:22:54 | 显示全部楼层
感激您的無私分享  很有趣的資料
发表于 2009-5-5 16:10:56 | 显示全部楼层
:victory:
发表于 2009-8-11 16:58:17 | 显示全部楼层
太好了,呵呵
发表于 2009-8-27 14:52:06 | 显示全部楼层
dddddddddddddddddddddd
发表于 2009-12-13 21:39:25 | 显示全部楼层
buguanzmyang,xiankankanzaishuo
发表于 2009-12-14 01:39:18 | 显示全部楼层
谢谢!!
GMT+8, 2025-12-9 03:28 , Processed in 0.026034 second(s), 6 queries , Gzip On, Redis On.
