查看: 4913|回复: 11
一篇rail-to-rail op的论文
发表于 2008-9-1 10:41:57 | 显示全部楼层 |阅读模式
A Compact Power-Efficient 3 V CMOS Rail-to-Rail Input/Output Operational Amplifier for VLSI Cell Libraries
Ron Hogervorst, John P. Tero, Ruud G. H. Eschauzier, and Johan H. Huijsing
Abstract— This paper presents a two-stage, compact, powerefficient 3 V CMOS operational ampiifier with rail-to-rail input and output ranges. Because of its small dle area of 0.04 mmz, it is very suitable as a VLSI library cell, The floatlng class-AB control is shifted into the summing circuit, which results in a noise and offset of the amplifier wh]ch are comparable to that of a three stage amplifier. A floating current source biases the combined summing circuit and the class-AB control. This current source has the same structure as the class-AB control which provides a power supply-independent quiescent current. Using the compact architecture, a 2.6 MHz amplifier with Miller compensation and a 6.4 MHz amplifier with cascoded-Miller compensation has been realized. The opamps have, respectively, a bandwidth-to-supplypower ratio of 4 MHz/mW and 11 MHz/mW for a capacitive load of 10 pF.
[ 本帖最后由 gogoll681 于 2008-9-1 10:44 编辑 ]
abbr_966a9cafcf60bbc6b3aa1dcde2591ab1.pdf
1.25 MB, 下载次数: 158 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-9-4 09:10:49 | 显示全部楼层
学习学习学习
发表于 2008-9-5 01:24:56 | 显示全部楼层
great.thanks
发表于 2008-9-15 05:32:01 | 显示全部楼层
发表于 2009-7-2 20:35:20 | 显示全部楼层
thanks for your sharing!
发表于 2009-7-3 09:29:29 | 显示全部楼层
Thanks!!!!
发表于 2009-9-1 20:37:24 | 显示全部楼层
总于找倒这边文章了
发表于 2020-5-16 12:15:04 | 显示全部楼层
谢谢
发表于 2020-5-16 13:29:53 | 显示全部楼层
谢谢分享!
发表于 2023-11-2 02:57:27 | 显示全部楼层
thanks
GMT+8, 2025-12-20 21:53 , Processed in 0.025236 second(s), 7 queries , Gzip On, Redis On.
