查看: 3265|回复: 1
求问:PCI总线架构下如何实现设备的配置
发表于 2005-6-17 14:46:02 | 显示全部楼层 |阅读模式
PCI总线架构下如何实现设备的配置:PCI总线上的配置访问分为两种:TYPE0访问和TYPE1访问。比如我的设计是bus0(主)上有一个设备slot0和一个pci-pci 桥。这个pci-pci 桥下挂了4个slot(slot1、2、3、4),总线为bus1(从)。很清楚的是如果访问slot0,则用TYPE0访问(slot0的idsel接bus0的p_AD【31】);如果访问slot1,则用TYPE1访问,如果bus number 吻合的话,就在bridge的等级上对slot1进行TYPE0访问(TYPE1的device number【15:11】为01110B,对应slot1的idsel接bus1的s_AD【30】)。
上述讲的是downstream。我的问题是桥芯片上的IDSEL引脚应该接什么,??
求求各位了
发表于 2005-7-22 13:49:45 | 显示全部楼层
Hello,
This is simple, you can simply connect the AD lines (high bits, 31, 30, 29, 28) to slot 1, 2, 3, and 4. When the PCI-PCI bridge pass the type 1 cycles (configuration), it will poll its AD line in turns to find out if there is a slot attached to it. If the slot has a device and the device reponds with a DEVSEL# assertion, it will continue the configuration; otherwise, it will skip this one, and try next AD line.
Hope this clarify your question.
GMT+8, 2025-12-29 13:07 , Processed in 0.016867 second(s), 7 queries , Gzip On, Redis On.
