楼主: kooba
请问关于pole-zero doublet的问题!
发表于 2008-11-2 17:29:08 | 显示全部楼层
wo yao kan kan
发表于 2008-11-4 00:14:27 | 显示全部楼层
kankan
发表于 2008-11-4 23:43:11 | 显示全部楼层
在单端输出的差放输出点的另一端,会产生一个非主极点,但同时会产生一个非主极点频率为2倍的零点,这就是极领点对,它对相位裕度的影响很小可以忽略。
发表于 2008-11-5 10:10:11 | 显示全部楼层
例如,在电路中,常用的一种方法是零点和极点抵消(左半平面),当两者不能完全重合但很近是,就存在一个偶合对。有些电路结构本身就具有这种情况,如gainboost电路。
发表于 2008-11-9 15:01:12 | 显示全部楼层
以前一直以为零级点相消是正好相等,谢谢analogicer的解释
发表于 2009-3-12 11:11:35 | 显示全部楼层
原帖由 analogicer 于 2008-11-5 10:10 发表
若零极点的位置一样的话,是否也应该被称为“pole-zero doublet“呢???
发表于 2009-3-12 11:32:16 | 显示全部楼层
好好看看,感谢分享!!
发表于 2009-3-12 11:49:55 | 显示全部楼层
主要是由电容引入的零点极点,这与频率有关
发表于 2009-3-12 12:22:44 | 显示全部楼层
零级点对是gainboosted 必须考虑的问题
发表于 2009-3-13 10:26:12 | 显示全部楼层
1. If pole and zero are exact the same, of course they are "transparent" to the signal path.
2. The pole-zero doublet effect requires pole and zero in the same s-plane(left s-plane). If zero in right plane while pole in left plane, even they have same value, it would not be a doublet.
3. Since pole-zero are very close, normally AC simulation can show its effects in the Amplitude-frequency/phase-frequency plot, however it does impact on transient response(linear part) as follows,
V(t)=Vo(1-k1*exp(-omegabw*t)+k2*exp(-omegaz*t)
where k2=(omegaz-omegap)/omegabw,
omegabw is the unity gain-bandwidth.
When omegaz=omegap, the linear step time constant depends on GBW only
4. You will never pay attention if the pole-zero doublet is at high frequency. E.g. like ahjua compensation, there is instrinsic pole-zero doublet and most of case regarded as fully cancelled and show very minor effects on transient response of the OPA with Ahjua compensation.
Hopefully you understand.
回复 支持 2 反对 0
GMT+8, 2025-12-28 09:42 , Processed in 0.018444 second(s), 3 queries , Gzip On, Redis On.
