楼主: benemale
【Morgan Kaufmann 2007 好书】Memory Systems: Cache, DRAM, Disk
发表于 2010-11-9 21:17:41 | 显示全部楼层
kan yi kan a
发表于 2010-11-9 21:20:39 | 显示全部楼层
kan yi kan a
发表于 2010-11-9 21:24:13 | 显示全部楼层
kan yi kan a
发表于 2010-11-9 22:23:31 | 显示全部楼层
keep it up, thx.
发表于 2010-11-10 10:12:57 | 显示全部楼层
看一看啊
发表于 2010-11-10 10:15:51 | 显示全部楼层
Gives the keyboard input focus to this widget (or its focus proxy) if this widget or one of its parents is the active window. The reason argument will be passed into any focus event sent from this function, it is used to give an explanation of what caused the widget to get focus. If the window is not active, the widget will be given the focus when the window becomes active.
First, a focus out event is sent to the focus widget (if any) to tell it that it is about to lose the focus. Then a focus in event is sent to this widget to tell it that it just received the focus. (Nothing happens if the focus in and focus out widgets are the same.)
发表于 2010-11-10 10:16:08 | 显示全部楼层
看一看啊
发表于 2010-11-10 10:18:08 | 显示全部楼层
看一看啊
发表于 2010-11-24 16:02:41 | 显示全部楼层
good thx
发表于 2010-11-24 16:09:48 | 显示全部楼层
good thx
GMT+8, 2025-12-26 03:38 , Processed in 0.017757 second(s), 3 queries , Gzip On, Redis On.
