查看: 3910|回复: 9
A New Concept for the Lateral DMOS Transistor for Smart Power IC's
发表于 2008-7-3 09:43:17 | 显示全部楼层 |阅读模式
A New Concept for the Lateral DMOS Transistor for Smart Power IC's:
A new type LDMOS with U-shape trench, filled with oxide is introduced, the U-trench can play a great role of enhancing the breakdown voltage, which is improved by the vertical current flow direction and buried breakdown point.
And the technique can also reduce the die size, A higher breakdown voltage can be obtained from the same drift length by U-trench than conventional LDMOS.
[ 本帖最后由 suk.qi 于 2008-7-3 09:50 编辑 ]
08Jul01 A New Concept for the Lateral DMOS Transistor for Smart Power IC's.rar
323.52 KB, 下载次数: 90 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-4-14 14:14:10 | 显示全部楼层
尋找 dmos 或  bcd process  這本看來可以參考 .. 不知道還有沒有人有研究 700v  DMOS PROCESS  ?
发表于 2009-4-14 21:35:31 | 显示全部楼层
谢谢楼主发帖,顶上去。
谢谢楼主共享,顶上去。
谢谢楼主共享,顶上去。
发表于 2010-5-13 21:16:02 | 显示全部楼层
我正需要这样的文章,谢谢!
发表于 2010-5-14 15:27:49 | 显示全部楼层
ieee paper that is old paper
发表于 2010-10-14 11:28:26 | 显示全部楼层
thanks
发表于 2010-10-14 12:16:32 | 显示全部楼层
谢谢楼主
发表于 2011-12-15 00:20:25 | 显示全部楼层
谢谢楼主
发表于 2011-12-16 20:19:04 | 显示全部楼层
kankan
发表于 2012-12-22 18:57:25 | 显示全部楼层
怎么打不开
GMT+8, 2025-12-15 12:08 , Processed in 0.029638 second(s), 8 queries , Gzip On, Redis On.
