查看: 15460|回复: 43
电荷泵性能比较(IEEE经典论文)
发表于 2008-6-20 09:55:03 | 显示全部楼层 |阅读模式
改论文对各种基本电荷泵的比较给出了充分的选择标准;跟人感觉不错,特此分享
A DC–DC Charge Pump Design Based on Voltage Douboler.pdf
208.67 KB, 下载次数: 613 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-20 10:48:32 | 显示全部楼层
欺负我们上不了ieee的,还要购买?
发表于 2008-6-20 13:29:22 | 显示全部楼层
Abstract—A novel organization of switched capacitor charge pump circuits based on voltage doubler structures is presented in this paper. Each voltage doubler takes a dc input and outputs a doubled dc voltage. By cascading voltage doublers the output voltage increases up to 2 times. A two-phase voltage doubler and a multiphase voltage doubler (MPVD) structures are discussed and design considerations are presented. A simulator working in the – realm was used for simplified circuit level simulation. In order to evaluate the power delivered by a charge pump, a resistive load is attached to the output of the charge pump and an equivalent capacitance is evaluated. A comparison of the voltage doubler circuits with Dickson charge pump and Makowski’s voltage multiplier is presented in terms of the area requirements, the voltage gain, and the power level. This paper also identifies optimum loading conditions for different configurations of the charge pumps. Design guidelines for the desired voltage and power levels are discussed. A two-stage MPVD was fabricated using MOSIS 2.0- m CMOS technology. It was designed with internal frequency regulation to reduce power consumption under no load condition.
发表于 2008-6-20 13:30:52 | 显示全部楼层
LZ,起码发个摘要吧!!
发表于 2008-6-20 21:57:17 | 显示全部楼层
虽然我们很缺乏分享精神
想想老外还得拿美元看IEEE
我也认了
发表于 2008-6-23 09:53:20 | 显示全部楼层
thanks
thanks
发表于 2008-6-23 09:54:40 | 显示全部楼层
thanks
发表于 2008-11-13 10:41:29 | 显示全部楼层
发表于 2009-2-4 09:01:30 | 显示全部楼层
Yes!!
发表于 2009-2-5 10:35:16 | 显示全部楼层
谢谢楼主分享!
GMT+8, 2025-10-16 22:24 , Processed in 0.026258 second(s), 6 queries , Gzip On, Redis On.
