查看: 4684|回复: 11
ANALYSIS AND CHARACTERIZATION OF A PROGRAMMABLE LOW-DROPOUT REGULATOR
发表于 2008-6-17 18:12:41 | 显示全部楼层 |阅读模式
   abstract
As portable electronic devices become a part of daily life, it creates a huge market for
electronic components for those battery driven devices. Low-dropout (LDO) voltage
regulator is an important part that provides steady DC supplies for other components.
Low power, low noise and high stability are the desired features of a regulator.
Detailed analyses on CMOS LDO design and the designs of two different compensation
schemes for LDO are presented in this thesis. Experimental results of the designed
compensation programmable low-power low-dropout (LDO) Voltage Regulator, in
comparison with an existing compensated LDO, are also presented.
The designed compensation implementation demonstrates a fast transient response and
high stability in all programmable output levels. Testing chip fabricated in a standard
0.35μm CMOS technology provided the important parameters of the regulator, e.g.
transient response, load regulation, line regulation, power supply rejection ratio (PSRR).
Research_Scholar_Thesis_Xiaofan_Qiu.pdf
309.75 KB, 下载次数: 55 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-17 23:14:41 | 显示全部楼层
谢谢分享。
 楼主| 发表于 2008-6-18 10:21:43 | 显示全部楼层
发表于 2008-6-18 16:13:19 | 显示全部楼层
太谢谢了!!!
发表于 2008-6-18 23:01:49 | 显示全部楼层
好像是中文的
头像被屏蔽
发表于 2008-6-19 07:58:01 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-6-19 10:44:39 | 显示全部楼层
先看看先看看
发表于 2008-6-19 10:48:14 | 显示全部楼层
英文的,华人
发表于 2009-1-26 13:24:14 | 显示全部楼层
good book
 楼主| 发表于 2009-3-20 15:15:23 | 显示全部楼层
gooooooooooooooooooooooood
GMT+8, 2025-12-13 23:09 , Processed in 0.024491 second(s), 8 queries , Gzip On, Redis On.
