查看: 7241|回复: 11
practical ESD design giude
发表于 2008-6-6 21:11:51 | 显示全部楼层 |阅读模式
from x-fab company
ESDguide_rel003.pdf
1.8 MB, 下载次数: 333 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-12-6 00:41:02 | 显示全部楼层
1 INTRODUCTION............................................................................................................. 4
2 ESD TEST MODELS ....................................................................................................... 5
2.1 Human Body Model (HBM) ...................................................................................................................5
2.2 Machine Model (MM) .............................................................................................................................7
2.3 Charged Device Model (CDM) ...............................................................................................................9
2.4 Transmission Line Pulsing (TLP).........................................................................................................11
2.5 System Level ESD Tests ........................................................................................................................16
2.6 Comparisons between the Test Methods .............................................................................................18
3 ESD PROTECTION MECHANISM ............................................................................ 21
3.1 ESD Failure Mechanism......................................................................................................................21
3.2 ESD Protection Device Types ...............................................................................................................22
3.3 ESD Robust Design...............................................................................................................................23
3.4 ESD Protection Strategies.....................................................................................................................25
3.5 ESD Design Window.............................................................................................................................27
3.6 NMOS-Related ESD Issues ...................................................................................................................28
3.7 NMOS Devices and Hot-electron Interactions ....................................................................................30
3.8 ESD and HV NMOS Devices ................................................................................................................31
3.9 Antenna Rule Violations .......................................................................................................................33
4 DEVICES FOR ESD PROTECTION........................................................................... 35
4.1 Diodes.....................................................................................................................................................35
4.2 Thick Field Oxide Clamps (TFO).........................................................................................................37
4.3 Silicon-Controlled Rectifier (SCR).......................................................................................................39
4.4 Medium Voltage Triggered SCR (MVTSCR).....................................................................................40
4.5 Low Voltage Triggered SCR (LVTSCR).............................................................................................41
4.6 Grounded Gate NMOS (ggNMOS) ......................................................................................................43
4.7 Gate Coupled NMOS (gcNMOS) .........................................................................................................45
4.8 Gate Biasing Clamps .............................................................................................................................45
4.9 BJT Clamps...........................................................................................................................................47
5 INPUT ESD PROTECTION SCHEMES..................................................................... 50
5.1 Dual-Diode Based Protection Circuit...................................................................................................50
5.2 Pi-Structure Based Protection Circuit .................................................................................................53
6 OUTPUT ESD PROTECTION SCHEMES................................................................. 54
6.1 Power Rail Based Output Protection ...................................................................................................54
6.2 Pad Based Output Protection ...............................................................................................................55
6.3 Open Drain Output Design ...................................................................................................................57
7 POWER CLAMPS.......................................................................................................... 60
7.1 Diode String Power Clamp ...................................................................................................................60
7.2 NMOS Power Clamp............................................................................................................................61
7.3 SCR Power Clamp................................................................................................................................61
7.4 MOSFET Switch Based Supply Clamps..............................................................................................63
7.5 Distributed MOS Supply Clamps.........................................................................................................66
7.6 Issues Related to MOS Supply Clamps................................................................................................68
8 LATCH-UP...................................................................................................................... 69
8.1 Background on Latch-up ......................................................................................................................69
8.2 Fab/Design Approaches to Avoid Latch-up.........................................................................................71
8.3 System Level Approaches to Avoid Latch-up .....................................................................................72
8.4 Latch-up Tests.......................................................................................................................................74
发表于 2011-11-7 00:54:36 | 显示全部楼层
GOOD
发表于 2012-6-27 21:46:15 | 显示全部楼层
很不错的东西啊~~~
发表于 2012-6-28 21:36:56 | 显示全部楼层
GOOD
发表于 2012-7-24 23:35:31 | 显示全部楼层
tkscc~
发表于 2012-7-25 09:28:25 | 显示全部楼层
頂一下!感謝無私分享!!
发表于 2014-1-19 14:45:34 | 显示全部楼层
3kyyyyyyyyyyyyy
发表于 2016-12-13 13:15:20 | 显示全部楼层
hen bu cuo de dong xi
发表于 2017-2-4 15:03:47 | 显示全部楼层
非常好,谢谢!
GMT+8, 2025-12-27 13:27 , Processed in 0.021357 second(s), 8 queries , Gzip On, Redis On.
