查看: 2515|回复: 0
PIC模拟异步串行通讯UART
发表于 2005-10-29 11:00:34 | 显示全部楼层 |阅读模式
pic乘除运算子程序
#define    STATUS    3
#define    skpb    skpnc    ;skip if borrowed
#define    skpnb    skpc    ;skip if no borrow
    cblock    0x10
PROD:2            ;2 bytes for production
QUOT:2            ;2 bytes for quotient
PAVRA            ;divider/multiplier
PAVRB            ;reminder / multiplier
PAVRC            ;additional byte space
mcount            ;loop counter
    endc
    org    000h
    ;movlw    0x20;
    ;movwf    PAVRA
    ;movlw    0x30
    ;movwf    PAVRB
    call    BBYTE_DIV
    goto    $-1
ROD:2 = PAVRA * PAVRB
BYTE_MUL
    clrf    PROD
    clrf    PROD+1
    movlw    .8
    movwf    mcount
_mul1
    rlf    PROD,f        ;left shift 16-bit with LSB=0
    bcf    PROD,0
    rlf    PROD+1,f
    rlf    PAVRA,w        ;make left-rotate shift
    rlf    PAVRA,f        ;and check MSB
    skpc            ;skip if MSB=1
    goto    _mul2        ;MSB=0
    ;do when MSB=1
    movf    PAVRB,w
    addwf    PROD,f
    skpnc
    incf    PROD+1,f
_mul2
    decfsz    mcount,f
    goto    _mul1
    retlw    0
;WORD divided by BYTE               =
ROD:2 / PAVRA                     =
;QUOT:2 = Quotient                  =
AVRB  = Reminder                  =
WBYTE_DIV
    movf    PAVRA,f
    skpnz
    retlw    1        ;return if divider=0
    clrf    PAVRB
    clrf    PAVRC
    clrf    QUOT
    clrf    QUOT+1
    movlw    .16
    movwf    mcount
_wdiv1
    rlf    QUOT,f        ;adjust Quotient
    rlf    QUOT+1,f
    bcf    QUOT,0
    rlf    PROD+1,w
    rlf    PROD,f
    rlf    PROD+1,f
    rlf    PAVRB,f
    rlf    PAVRC,f
    movf    PAVRA,w
    subwf    PAVRB,f
    skpb            ;skip if borrow
    goto    _wdiv2
    ;if borrow
    btfsc    PAVRC,0
    goto    _wdiv2
    addwf    PAVRB,f
    bcf    PAVRC,0
    goto    _wdiv3
_wdiv2    ;if no borrow
    bcf    PAVRC,0
    bsf    QUOT,0
_wdiv3
    decfsz    mcount,f
    goto    _wdiv1
    retlw    0
;BYTE divided by BYTE               =
;PROD[0] / PAVRA                    =
;QUOT[0] = Quotient                 =
;PAVRB   = Reminder                 =
BBYTE_DIV
    movf    PAVRA,f
    skpnz
    clrf    PAVRB        ;clear reminder
    clrf    QUOT        ;clear quotient
    movlw    .8
    movwf    mcount        ;for 8 times shift
_bdiv1
    bcf    QUOT,0        ;left shift i bit
    rlf    PROD,w        ;get 1 bit, MSB first
    rlf    PROD,f        ;do rotate shift
    rlf    PAVRB,f        ;set to LSB of reminder
    movf    PAVRA,w        ;reminder - divider
    subwf    PAVRB,f
    goto    _bdiv2
    ;do if borrowed
    addwf    PAVRB,f        ;cancel subtraction
    goto    _bdiv3        ;go for next
_bdiv2    ;do if no borrow
    bsf    QUOT,0        ;reminder > divider
                ;update quotient
_bdiv3
    decfsz    mcount,f    ;loop test
    goto    _bdiv1        ;do 8 times
    retlw    0        ;completed
    END
GMT+8, 2025-12-20 17:49 , Processed in 0.015703 second(s), 7 queries , Gzip On, Redis On.
