查看: 18619|回复: 59
好书!Signal Processing Requirements for WiMax 802.16e Base Station
发表于 2008-6-1 11:34:25 | 显示全部楼层 |阅读模式
Abstract
802.16e provides specifications for non line of sight, mobile wireless communications in the frequency range of 2-6 GHz. It is well implemented by using OFDMA as its physical layer scheme. The OFDM symbol time (sT) is to be selected depending on the channel conditions, available bandwidth and, simulations provide a means of selecting right values of sTin different channel conditions. Additionally it has been shown that certain values of sT outperform others in all conditions, thus invalidating their use. Moreover, a solution proposed by INTEL is also analyzed.
One of the major requirements of OFDM is high synchronization. Detecting the timing offset of a new mobile user, entering the network, which is not time aligned using cross-correlation and ‘auto-correlation’ in time domain and cross-correlation in frequency domain at the base station has been simulated. Results point that the processing load can be significantly reduced by using frequency domain correlation of the received data or by using ‘auto-correlation’ followed by cross-correlation on localized data.
The use of adaptive antenna system in 802.16e improves the system performance, where beamforming is implemented in the direction of desired user. Capon’s method and MUSIC method have been simulated to compute the direction of arrival for OFDMA uplink. A new user, while in the ranging process, transmits data with unknown time offset and unknown direction. The thesis describes the procedure to find the two unknown one after another.
PART 0: INTRODUCTION....................................................................................................1
0.1 GOAL OF THE THESIS.........................................................................................................3
0.2 REPORT OUTLINE...............................................................................................................3
0.3 INTRODUCTION TO WIMAX..............................................................................................3
0.3.1 802.16c.................................................................................................................................3
0.3.2 802.16a.................................................................................................................................4
0.3.3 802.16d.................................................................................................................................4
0.3.4 802.16e.................................................................................................................................4
0.4 OFDM SYSTEM DESCRIPTION............................................................................................5
0.4.1 Effects of Receiver performance............................................................................................7
PART 1: CHANNEL ESTIMATION.....................................................................................9
1.1 INTRODUCTION..................................................................................................................9
1.2 UP LINK TRANSMISSION....................................................................................................9
1.3 THE BLOCK DIAGRAM.....................................................................................................10
1.3.1 Transmitter.........................................................................................................................11
1.3.2 Channel...............................................................................................................................12
1.3.3 Receiver..............................................................................................................................15
1.4 PROBLEM DESCRIPTION...................................................................................................17
1.5 SIMULATION RESULTS.....................................................................................................18
1.5.1 Performance in AWGN channel..........................................................................................18
1.5.2 Performance in a Rayleigh Fading Channel.......................................................................20
1.5.3 Effect of mobile speed..........................................................................................................23
1.5.4 Performance in presence of Multipath................................................................................24
1.5.5 Effect of multipath delay spread..........................................................................................28
1.5.6 Effect of Channel coding.....................................................................................................30
1.6 DISCUSSION.....................................................................................................................32
PART 2: RANGING..............................................................................................................34
2.1 INTRODUCTION................................................................................................................34
2.2 PROBLEM DESCRIPTION...................................................................................................35
2.3 TIMING OFFSET CALCULATION.........................................................................................35
2.3.1: Cross-correlation in time domain......................................................................................35
2.3.2: Auto-correlation in time domain........................................................................................36
2.3.3: Correlation in frequency domain.......................................................................................37
2.4 FREQUENCY AND POWER OFFSET CALCULATION.............................................................39
2.5 SIMULATION RESULTS.....................................................................................................39
2.6 PROCESSING LOAD CALCULATION...................................................................................42
PART 3: ANTENNA BEAMFORMING.............................................................................46
3.1 INTRODUCTION................................................................................................................46
3.2 BEAMFORMING BASICS....................................................................................................47
3.3 TYPES OF BEAMFORMING.................................................................................................48
3.4 PARAMETERS EFFECTING BEAMFORMING........................................................................50
3.5 ADAPTIVE ANTENNA SYSTEM FOR OFDMA IN 802.16E..................................................50
3.6 DIRECTION OF ARRIVAL COMPUTATION (DOA)...............................................................53
3.6.1 Capon’s method...................................................................................................................53
3.6.2 MUSIC algorithm................................................................................................................54
3.7 SIMULATION RESULTS.....................................................................................................54
3.8 CONCLUSION...................................................................................................................57
A. REFERENCES..................................................................................................................60
B. ACRONYMS......................................................................................................................62 ix
Signal Processing Requirements for WiMax 802.16e Base Station.pdf
1.41 MB, 下载次数: 429 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-1 13:54:23 | 显示全部楼层
谢谢 ,很好
发表于 2008-6-1 13:56:18 | 显示全部楼层
谢谢 ,很好
发表于 2008-6-1 22:40:32 | 显示全部楼层
发表于 2008-6-3 13:27:08 | 显示全部楼层
wimax的东西好流行啊, 论坛里都是的说。 哈哈
看来大势所趋啊
头像被屏蔽
发表于 2008-6-5 13:47:25 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-6-16 09:04:09 | 显示全部楼层
好就一个字
发表于 2008-7-1 11:33:31 | 显示全部楼层
好书!
发表于 2008-7-10 10:51:05 | 显示全部楼层
多谢,学习学习
头像被屏蔽
发表于 2008-7-18 15:13:22 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-9-14 03:04 , Processed in 0.018962 second(s), 6 queries , Gzip On, Redis On.
