查看: 6421|回复: 23
SPIC中器件的设计模型及参数提取研究
发表于 2008-5-26 14:34:52 | 显示全部楼层 |阅读模式
Abstract
Device model is a bridge that connects circuit design with process and it is very
important to circuit design. Power devices such as LDMOS have a lot of advantages
such as high switch speed and good thermal stability. It promotes SPIC to achieve and
develop that LDMOS can easy to integrate with other devices. Now, many
researchers are engaged in the work of develop LDMOS model, but hitherto there
isn’t an omnipotent model can be applied to all LDMOS that have different structure.
This project is supported by national 863 item“smart power integration tech
technique research”(2002AA11Z1540). We have done the following work in this
paper: 1. designing the key device of switching power supply management Integrated
Circuit — a single crystal diffused LDMOS. 2. Extracting model parameters of low
voltage MOS by using the software AURORA. 3. Testing MOS transistors including
high voltage LDMOS and low voltage MOS after the process experiment, then
analyze the results of test.
During the design of the high voltage LDMOS and develop its model, we use 2D
numerical simulator MEDICI to do the device simulation and optimizing design, then
we get the structure parameter of the LDMOS. Also, we analyze on the LDMOS
quasi-saturation mechanisms and the characteristic of quasi-drain. Then a sub-circuit
model is shown based on the concept of macro model.
During extracting the model parameters of MOS transistors, a parameter
extraction software AURORA is used. First, we learn what’s AURORA and how to
use it, and then we illustrate how to extract model parameters and how to get
satisfying results in details.
SPIC中器件的设计模型及参数提取研究.part1.rar
1.91 MB, 下载次数: 107 , 下载积分: 资产 -2 信元, 下载支出 2 信元
SPIC中器件的设计模型及参数提取研究.part2.rar
1.7 MB, 下载次数: 102 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-5-26 22:50:11 | 显示全部楼层
bucuo xiexie
发表于 2008-5-27 19:26:42 | 显示全部楼层
发表于 2008-5-27 23:51:27 | 显示全部楼层
有推有下喔
发表于 2008-5-29 01:40:25 | 显示全部楼层
好东西,收留备用
发表于 2008-6-25 15:31:08 | 显示全部楼层
goodgoodgoodgoodgoodgood
发表于 2008-6-25 16:06:58 | 显示全部楼层
up  uo
发表于 2008-6-25 16:33:30 | 显示全部楼层
good material
thanks!
发表于 2008-6-25 20:36:49 | 显示全部楼层
原来是一篇学位论文。
发表于 2008-6-26 20:58:22 | 显示全部楼层
谢谢了
GMT+8, 2025-12-25 01:00 , Processed in 0.028941 second(s), 6 queries , Gzip On, Redis On.
