查看: 2403|回复: 1
求教:软连接冲突
发表于 2008-5-22 20:07:15 | 显示全部楼层 |阅读模式
小弟最近在用calibre做lvs验证,遇到一个生词,软连接冲突,请问有没有哪位大侠能给小弟说一下,什么叫做软连接冲突?非常感谢~!
发表于 2009-2-16 23:27:48 | 显示全部楼层
即command file里的sconnect,你可以在svrf里查查看就知道了。
Establishes connections from the upper_layer polygons to lower_layer polygons. Connections
are unidirectional; node numbers are passed from upper_layer to lower_layer, but not in the
other direction. Connections are made through the contact_layer argument if you use the BY
keyword.
GMT+8, 2025-12-21 15:29 , Processed in 0.012943 second(s), 5 queries , Gzip On, Redis On.
