查看: 1877|回复: 0
[原创] 2812SCI求助
发表于 2008-5-12 20:09:33 | 显示全部楼层 |阅读模式
一个很简单程序,但不知道什么问题,每次都只收到qf,可正确的应该是qabcdef
#include "DSP28_Device.h"
unsigned char Sci_VarRx[]="abcdef";
unsigned char *p=Sci_VarRx;
unsigned int i=0,j;
unsigned int Send_Flag;
void main(void)
        /*初始化系统*/
        InitSysCtrl();
        /*关中断*/
        DINT;
        IER = 0x0000;
        IFR = 0x0000;
        /*初始化PIE中断*/
        InitPieCtrl();
        /*初始化PIE中断矢量表*/
        InitPieVectTable();
        /*初始化SCIA寄存器*/
    InitSci();
    Send_Flag = 0;
//    #if SCIA_INT
        /*设置中断服务程序入口地址*/
        EALLOW;        // This is needed to write to EALLOW protected registers
        PieVectTable.TXAINT = &SCITXINTA_ISR;
//        PieVectTable.RXAINT = &SCIRXINTA_ISR;
        EDIS;   // This is needed to disable write to EALLOW protected registers
        /*开中断*/
        IER |= M_INT9;
  //        #endif
        EINT;   // Enable Global interrupt INTM
        ERTM;        // Enable Global realtime interrupt DBGM
    SciaRegs.SCITXBUF='q';
        while(1)
interrupt void SCITXINTA_ISR(void)     // SCI-A
    while(*p!='\0')
                       SciaRegs.SCITXBUF=*p;
                        p++;
        PieCtrl.PIEACK.all= PIEACK_GROUP9;
        EINT;
GMT+8, 2025-12-23 05:49 , Processed in 0.020085 second(s), 6 queries , Gzip On, Redis On.
