查看: 3516|回复: 6
熟悉EMC产品的看过来 12~17万招聘技术支持工程师
发表于 2008-5-12 11:56:04 | 显示全部楼层 |阅读模式
年薪12~17W招聘CLARiiON/Celerra PREM技术支持工程师
CLARiiON/Celerra PREM, Technical Support Engineer
General Summary
Applies advanced systems level technical expertise to resolve standard to complex systems level customer issues. Customer issues may be received by Support Centers through automated dial-homes, voice initiated technical calls from EMC Customers, Customer Engineers, or remote maintenance calls and Web Support Calls. Identifies and provides resolutions to a diverse range of complex technical problems. Mentors others in providing validated technical information, support process instructions and special support requirements. Engineers provide problem determination and resolution for customer issues. Develop and implement resolutions to identified problems, and follows standard practices and procedures. Identifies, records and works with management to proactively revise current procedures and tools to improve customer satisfaction. May need to engage or escalate to more senior resources to resolve more complex issues.
Principal Duties and Responsibilities
  • Applies advanced technical expertise using standard operating and diagnostic protocols to resolve standard to complex system level issues. Identifies, documents and escalates customer issues to senior resources. Uses standard internal and external diagnostic test equipment and product trace and logging procedures.
  • Effectively communicates procedural and technical issues to internal and external customers in a fast paced and customer critical environment. Maintains a “closed-loop” communication style assuring all appropriate individuals are notified of ongoing issues and problem resolution status. Responsible for sharing all acquired knowledge concerning problem resolution. . Contributes to centralized problem identification and resolution database. Leads efforts in facilitating problem recreation and failure analysis of systems level issues. Recommends and utilizes a wide variety of test equipment, diagnostic tools and techniques used in problem resolution. May provide documentation and direct feedback to Field Technical Specialists, Account Managers, Sales and other EMC Technical Support co-workers as appropriate.
  • Identifies and interprets interoperability and support matrixes. Identifies, reviews, creates and delivers timely and highly focused training programs and/or serviceability enhancements within the Field and Technical Support Departments.
  • Communicates effectively to internal and external customers as necessary through a variety of mediums.
  • Monitors and tracks all service calls, provides call status updates at regular intervals and communicates status to customers using Call Tracking Databases.
  • Validates technical information and issues early warnings and disseminates information as needed. As a 24X7X365 organization shift work, holidays and on-call responsibilities may be required.
  • Continues to develop technical and business knowledge related to EMC products.
  • Makes a recommendation to higher level technical support engineers or management for improving processes, standards and strategies. Regularly submits content to the knowledge database.
  • Regularly reviews and approves submitted content to the knowledge database.
  • Escalates to senior resource or to engineering all necessary analysis to open engineering defect investigation.
  • Trains and mentors less experienced team members in working technical issues through to resolution
  • Help to manage the day to day workings of the business including the monitoring of work flow and metrics for the team.
  • Help drive Support projects as assigned by management.
  • Performs other duties as assigned.
Skills
  • Position prefers a Bachelor of Science Degree in Computer Science, Engineering, or equivalent industry related experience.
  • Pursuing or is established as SME in 2+ identified technical areas.
  • Candidate must demonstrate working knowledge with major software/hardware vendor.
  • Candidate must demonstrate ability to react quickly to interrupt driven workload and handle multiple tasks simultaneously.
  • Candidate must demonstrate excellent customer service skills, including organizational, interpersonal communication, and presentation skills.
  • A strong sense of urgency and professionalism is essential.
  • Must have the ability to work independently and as part of a team, with minimal supervision.
  • Must possess excellent research/technical and troubleshooting skills.
  • Ability to support and communicate with customers over the phone or preferred communication method by customer.
  • Internal candidates should demonstrate specific knowledge of EMC products. Familiarity with Customer Service Technical Support and/or customer facing/orientated environments is preferred.
  • Education Required: Bachelors (or equivalent experience)
  • Experience Required: 4+ Years
  • Physical Requirements: No
  • Other: Travel may be required.
  • Language Skills Desirable.
  • May be required to change work patterns as business dictates.
要求英文不错,如果您有兴趣,或者您的朋友可能有兴趣,可直接和我联系哦。
TEL: +021-6360.1166-610
FAX: +021-6360.6689
CELL: 13816390336
MAIL: sean.wanyuanhu@gmail.com
MSN: dnv@live.com
 楼主| 发表于 2008-5-20 15:48:59 | 显示全部楼层
出差归来,过来顶顶
 楼主| 发表于 2008-5-23 10:27:59 | 显示全部楼层
继续顶顶的
 楼主| 发表于 2008-5-27 14:39:58 | 显示全部楼层
过来顶顶,还是没招勾人
www.semarketing.cn
 楼主| 发表于 2008-5-29 14:19:37 | 显示全部楼层
发表于 2008-6-1 09:49:34 | 显示全部楼层
我们回国专门推销过我们这里的产品电磁兼容和信号完整性解决方案,IBM 和CISCO 等大公司一向跟我们合作很好,可惜国内没人感兴趣,大部分的企业只选择掏钱给国家标准机构,而不愿意在技术上投入更多,我很不理解,但是国内情况确实如此,所以电磁兼容的人才都不愿意回去。
 楼主| 发表于 2008-6-3 09:56:17 | 显示全部楼层
这个是存储,呵呵。
GMT+8, 2025-12-23 11:53 , Processed in 0.019392 second(s), 6 queries , Gzip On, Redis On.
