楼主: benemale
[原创] 【运放经典】Design With Operational Amplifiers And Analog Integrated Circuits
发表于 2009-5-20 12:09:47 | 显示全部楼层
再下最后一部分
发表于 2009-5-20 23:09:35 | 显示全部楼层
下了,感谢版主
发表于 2009-5-21 11:59:04 | 显示全部楼层
thank you very much
发表于 2009-5-21 12:18:59 | 显示全部楼层
thank you very much
发表于 2009-5-23 08:18:41 | 显示全部楼层
xiexie
发表于 2009-5-23 08:20:20 | 显示全部楼层
已下载,谢谢分享
发表于 2009-5-24 10:41:12 | 显示全部楼层
谢谢,已下!
发表于 2009-5-25 09:15:48 | 显示全部楼层
此书不错
发表于 2009-5-26 08:59:54 | 显示全部楼层
This book can be an excellent resource for any Analog IntegratedCircuit Design Electrical Engineering student or practicing engineer.The book can assist in the modeling of IC devices such as transistors,resistors, and capacitors. It also sensibly covers the building blocksof analog integrated circuits: gain stages, output stages, levelshifters, current sources and mirrors. The reader is expected tohave a general understanding of electronics, frequency-domain analysisprocedures, and understand basic Pspice operations. The book generallycovers enough material for a half-year of courses at theupper-division/graduate level although the book could certainly beuseful for a single class.
The material generally starts out asbasic and proceeds to a complex level. There are helpful figures anddiagrams on nearly every page and the organization is generallysensible and intuitive. There are many worked examples and hundreds ofend-of-chapter problems. The text is supported by a website that offersdownloadable design projects, additional examples, and design software.Franco has done an admiral job at presenting a complicated subject.
Here's a brief description of SOME of the topics found in each chapter:
1)Basic amplifier concepts and arrangements are explored. Also coversnegative feedback, the loop gain, and basic circuit analysis.
2)Current-to-Voltage & Voltage-to-Current Converters, Current,Difference, Instrumentation, and Transducer Bridge Amplifiers.
3) Active Filters.  Transfer Function, 1st order, KRC, multiple-feedback, state-variable, audio, and biquad filters.
4) Filter Approximations, switched-capacitor, universal sc filters, and cascade design.
5) Low-input bias-current Op amps, low-input-offset-voltage Op Amps, Op Amp Circuit Diagrams, and Input offset Voltage.
6)Open and Closed loop response. Transient Response, Input and OutputImpedances, and effect of Finite GBP on Filters and Integrator Circuits.
7) Noise Dynamics and Properties.  Sources of Noise and Low-Noise Op Amps.
8)Stability problems. Stability of CFA Circuits and in Constant-GBP OpAmp Circuits. Internal and External Frequency Compensation.
9) Schmitt Triggers, analog switches, voltage comparators, and precision rectifiers.
10) Sine, Triangular, Sawtooth, and Monolithic Wave Generators.  Also Multivibrators and V-F and F-V Converters.
11) Voltage References and Regulators.  Switching, linear, and monolithic switching regulators.
12) Performance Specifications, D-A and A-D Conversion Techniques.  Oversampling Converters and Multiplying DAC Applications.
13)Nonlinear Amplifiers. Phase-Locked Loops, Monolithic PLLs, AnalogMultipliers. Log/Antilog and Operational Transconductance Amplifiers.
发表于 2009-5-26 09:02:54 | 显示全部楼层
This is a very good intermediate text for op amp design. Someacquaitance with op amps will be needed before reading this bookbecause the learning curve is steep in the first chapter. However, theapproach is thorough and professionally presented. The book is morethan a cookbook. Furthermore, the book does not stop with the single opamp, but discusses the use of op amp(s) in circuits. The book isperfectly suited for prototyping the many circuits contained betweenits two covers. Since my interest was in instrumentation amplifiers, Idecided to reduce the circuits of chapter 2 to practice. It was a reallearning experience. I think chapter titles will further indicate thecomprehensive nature of the book: (1) OA Fundamentals, (2) Circuits w/Resistive Feedback, (3,4) Active Filter, (5) Static OA Limitations, (6)Dynamic OA Limitations, (7) Noise, (8) Stability, (9) NonlinearCircuits, (10) Signal Generators, (11) Voltage References andRegulators, (12) D-A & A-D Converters, (13) Nonlinear Amplifiers& Phase-Locked Loops.
GMT+8, 2025-10-26 21:52 , Processed in 0.020265 second(s), 3 queries , Gzip On, Redis On.
