我在笔记本上安装Ubuntu 7.10版, 然后安装IC610.
ic610安装时没有出现任何提示库找不到之类的提示,安装顺利完成.
之后进行配置:
用户目录是/home/zhh
在.bashrc中加入
alias lmli='/EDA/Cadence/IC610/tools/bin/lmgrd -c /EDA/Cadence/IC610/share/license/license.dat'
export OA_HOME=/EDA/Cadence/IC610/OA
export CDS_ROOT=/EDA/Cadence/IC610
#export MMSIM_ROOT=/media/linux/mmsim61
export [email=CDS_LIC_FILE=5280@zhh]CDS_LIC_FILE=5280@zhh[/email]
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export CDS_Netlisting_Mode=Analog
#export PATH=$MMSIM_ROOT/tools/bin MMSIM_ROOT/tools/spectre/bin CDS_ROOT/tools/bin CDS_ROOT/tools/dfII/bin:$PATH
export PATH=$CDS_ROOT/tools/bin:$CDS_ROOT/tools/dfII/bin:$PATH
export MOZILLA_HOME=/usr/bin/netscape
因为我没安装MMSIM,所以把有关MMSIM的注释掉了.
控制台运行命令以及输入如下:
zhh@zhh:~$ lmli
12:09:34 (lmgrd) -----------------------------------------------
12:09:34 (lmgrd) Please Note:
12:09:34 (lmgrd)
12:09:34 (lmgrd) This log is intended for debug purposes only.
12:09:34 (lmgrd) In order to capture accurate license
12:09:34 (lmgrd) usage data into an organized repository,
12:09:34 (lmgrd) please enable report logging. Use Macrovision's
12:09:34 (lmgrd) software license administration solution,
12:09:34 (lmgrd) FLEXnet Manager, to readily gain visibility
12:09:34 (lmgrd) into license usage data and to create
12:09:34 (lmgrd) insightful reports on critical information like
12:09:34 (lmgrd) license availability and usage. FLEXnet Manager
12:09:34 (lmgrd) can be fully automated to run these reports on
12:09:34 (lmgrd) schedule and can be used to track license
12:09:34 (lmgrd) servers and usage across a heterogeneous
12:09:34 (lmgrd) network of servers including Windows NT, Linux
12:09:34 (lmgrd) and UNIX. Contact Macrovision at
12:09:34 (lmgrd) www.macrovision.com for more details on how to
12:09:34 (lmgrd) obtain an evaluation copy of FLEXnet Manager
12:09:34 (lmgrd) for your enterprise.
12:09:34 (lmgrd)
12:09:34 (lmgrd)
12:09:34 (lmgrd)
12:09:34 (lmgrd) Can't make directory /usr/tmp/.flexlm, errno: 2(No such file or directory)
12:09:34 (lmgrd) Can't open /usr/tmp/.flexlm/lmgrdl.6447, errno: 2
license manager: can't initialize:
License path: /EDA/Cadence/IC610/share/license/license.dat
FLEXnet Licensing error:0,0. System Error: 13 " Permission denied"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
12:09:34 (lmgrd) Can't remove statfile /usr/tmp/.flexlm/lmgrdl.6447: errno No such file or directory
zhh@zhh:~$ icfb&
[1] 6542
zhh@zhh:~$ /EDA/Cadence/IC610/tools/dfII/bin/icfb: 97: cds_plat: not found
/EDA/Cadence/IC610/OA/bin/sysname: 328: /bin/awk: not found
/EDA/Cadence/IC610/tools/dfII/bin/32bit/icfb.exe: error while loading shared libraries: libelf.so.1: cannot open shared object file: No such file or directory
请大侠帮忙看一下是什么问题?
[ 本帖最后由 zhh124 于 2008-4-25 13:38 编辑 ] |
