查看: 14178|回复: 47
【Texas Instruments】 Nulling Input Offset Voltage of Operational Amplifiers
发表于 2008-4-4 17:16:04 | 显示全部楼层 |阅读模式
The input offset voltage of operational amplifiers (op amps) arises from unavoidable
mismatches in the differential input stage of the op-amp circuit caused by mismatched
transistor pairs, collector currents, current-gain betas(b), collector or emitter resistors, etc.
This application report describes the effects of mismatched components on the input offset
voltage, and proposes using an external null circuit to reduce the input offset voltage of an
amplifier. It also suggests a means for computing proper values of resistors in the null circuit
in order to provide appropriate input-offset-voltage compensation.
[ 本帖最后由 jerwei 于 2008-4-4 20:54 编辑 ]
Nulling Input Offset Voltage of Operational Amplifiers.pdf
94.9 KB, 下载次数: 368 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-4-4 17:20:55 | 显示全部楼层
檔案終於上傳成功了!!!    開心丫
[ 本帖最后由 jerwei 于 2008-4-4 20:53 编辑 ]
 楼主| 发表于 2008-4-4 20:56:18 | 显示全部楼层
Contents
1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
2 Effect of Component Mismatches in the Input Offset Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
2.1 Effect of Collector-Resistor (Rc) Mismatch on Vos . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
2.2 Effect of Mismatched Transistors on Vos . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
3 External Null Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
3.1 Effect of the Potentiometer on Vos . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
3.1.1 TLC070 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
3.1.2 THS4011 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
3.2 Effect of Additional Temperature-Coefficient Resistors on Vos . . . . . . . . . . . . . . . . . . . . . . . . . . 8
3.2.1 Low Temperature-Coefficient Resistor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
3.2.2 Effect of High Temperature-Coefficient Resistor (Thermistor) on Vos . . . . . . . . . . . . . . 9
3.2.3 TLC070 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
3.2.4 THS4011 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
4 Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
5 References . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
发表于 2008-4-4 22:14:38 | 显示全部楼层
xiexie
发表于 2008-4-6 00:25:16 | 显示全部楼层
那就看看吧
发表于 2008-7-1 00:50:33 | 显示全部楼层
很需要 谢谢
发表于 2008-7-1 11:18:02 | 显示全部楼层
Thanks for sharing !!!
发表于 2008-9-27 13:05:59 | 显示全部楼层
看一看!!!!!!!!!!!
发表于 2008-12-27 10:29:31 | 显示全部楼层
bucuo
发表于 2009-6-8 20:21:21 | 显示全部楼层
正好需要
GMT+8, 2025-11-23 18:58 , Processed in 0.034225 second(s), 4 queries , Gzip On, Redis On.
