查看: 2669|回复: 0
quartus出错!
发表于 2003-10-15 18:31:18 | 显示全部楼层 |阅读模式
放置的lvds引脚编译时出错!
Error: Can't place pin D_OUT in I/O bank 1. It uses I/O standard LVDS, with a VCCIO requirement incompatible with other output or bidirectional pins in the I/O bank that use VCCIO 3.3V
Info: Pin clk in I/O bank 1 uses VCCIO 3.3V
GMT+8, 2025-12-26 17:16 , Processed in 0.019219 second(s), 6 queries , Gzip On, Redis On.
