发表于 2009-10-20 14:48:08
显示全部楼层
PACE is the easiest way to place RocketIO?transceivers and BREFCLK pins.
You can also do this in Floorplanner, the UCF file, or in the HDL code.
You can see the sites for the Gigabit Transceiver (GT) components, which are indicated by squares
above the BRAM columns.
?The GT site on the right is populated.
?The GT site on the left is about to be populated.
?The user is placing the gt0_XAUI component from the Design Object List window (the diamond
above the GT site on the left). |
