查看: 9692|回复: 16
[讨论] 关于primetime的问题
发表于 2012-10-31 10:49:27 | 显示全部楼层 |阅读模式
set link_path “* xxxx” .   这儿的“*”有什么作用,而且是必须要的...
set_operating_conditions -analysis_type bc_wc. 这儿不管设哪种analysis_type,pt跑出来始终用的vco模式,这又是什么原因啊!!!!!
“set_operating_conditions -analysis_type bc_wc -min u055lscspmvbbr_110c-40_bc -max u055lscspmvbbr_090c125_wc”
跑出来是:Loading verilog file '/home/yangqg/projects/encounter/out/netlist/cfg_top_v12H.v'
Loading db file '/home/yangqg/projects/encounter/in/lib/u055lscspmvbbr_110c-40_bc.db'
Loading db file '/home/yangqg/projects/encounter/in/lib/u055lscspmvbbr_090c125_wc.db'
Linking design cfg_top...
Information: Removing 17 unneeded designs..... (LNK-034)
Information: 878 (72.26%) library cells are unused in library u055lscspmvbbr_110c-40_bc.....
Information: 1215 (100.00%) library cells are unused in library u055lscspmvbbr_090c125_wc.....
Information: total 2093 library cells are unused.
Information: Issuing set_operating_conditions for setting analysis mode on_chip_variation. (PTE-037)
set_operating_conditions -analysis_type on_chip_variation  -library [get_libs {u055lscspmvbbr_110c-40_bc.db:u055lscspmvbbr_110c-40_bc}]
Design 'cfg_top' was successfully linked.
Warning: The BC_WC analysis mode will be phased out in future releases. (PT-009)
Warning: Creating a clock on internal pin 'U41809/Z'. (UITE-130)
Warning: Creating a clock on internal pin 'U41812/Z'. (UITE-130)
Information: Derived library resistance unit is 1.000000 Kohm (Time unit is 1 ns, and Capacitance unit is 1.000000 pF). (DES-028)
“set_operating_conditions -analysis_type single -min u055lscspmvbbr_110c-40_bc -max u055lscspmvbbr_090c125_wc”
跑出来的是:
发表于 2012-10-31 13:52:46 | 显示全部楼层
*是指读到内存中的设计吧,当然是必须的。
ocv 这个不太清楚,贴报告上来看吧
 楼主| 发表于 2012-10-31 14:20:54 | 显示全部楼层
回复 2# chrisyl
    贴出来了,多谢你的解答
发表于 2012-10-31 21:26:53 | 显示全部楼层
哈哈  我也不知道哈 同求
发表于 2012-11-1 10:19:39 | 显示全部楼层
回复 3# 龙溪小泮
   你报一条路径的时序,看实际用的是bc_wc还是ocv呢?
发表于 2012-11-5 21:24:35 | 显示全部楼层
设了derating就会自动切换到OCV
发表于 2015-7-8 20:16:05 | 显示全部楼层
感谢分享
发表于 2016-1-26 18:55:17 | 显示全部楼层
感谢回答
发表于 2016-3-30 20:00:20 | 显示全部楼层
搞清bc_wc和ocv的区别。
发表于 2016-8-15 21:45:06 | 显示全部楼层
Hi, How to learn prime time tool?
GMT+8, 2025-9-11 02:53 , Processed in 0.016600 second(s), 3 queries , Gzip On, Redis On.
