楼主: benemale
★新书上架—低功耗设计☆Closing the Power Gap Between ASIC & Custom
发表于 2009-12-27 16:22:47 | 显示全部楼层
thanks!!!
发表于 2009-12-27 16:41:41 | 显示全部楼层
不错,支持!!!
发表于 2009-12-31 19:59:42 | 显示全部楼层
谢谢楼主,学习一下
发表于 2010-1-1 09:03:22 | 显示全部楼层
有了,学习 1# benemale
发表于 2010-1-2 10:13:37 | 显示全部楼层
1# benemale
发表于 2010-1-2 15:00:07 | 显示全部楼层
CONTENTS
1. Introduction 1
David Chinnery, Kurt Keutzer
1.1 Definitions: ASIC and custom.........................................................1
1.2 What is a standard cell ASIC methodology?...................................3
1.3 Who should care about this book?...................................................6
1.4 Organization of the rest of the book ................................................8
1.5 What’s not in this book....................................................................9
CONTRIBUTING FACTORS
2. Overview of the Factors Affecting the Power Consumption 11
2.1 Introduction....................................................................................11
2.2 Process technology independent FO4 delay metric ......................12
2.3 Components of power consumption..............................................14
2.4 ASIC and custom power comparison ............................................15
2.5 Factors contributing to ASICs being higher power.......................19
2.6 Summary........................................................................................47
3. Pipelining to Reduce the Power 55
3.1 Introduction....................................................................................57
3.2 Pipelining overheads......................................................................61
3.3 Pipelining power and delay model ................................................67
3.4 ASIC versus custom pipelining .....................................................74
3.5 Other factors affecting the power gap ...........................................81
3.6 Other factors affecting the minimum energy per operation ..........81
3.7 Summary........................................................................................84
4. Voltage Scaling 89
4.1 Introduction....................................................................................89
4.2 Delay..............................................................................................90
4.3 Switching power ............................................................................94
4.4 Short circuit power ........................................................................95
4.5 Leakage power...............................................................................97
4.6 0.13um data for total power...........................................................99
4.7 Summary......................................................................................104
DESIGN TECHNIQUES
5. Methodology to Optimize Energy of Computation for SOCs 107
Jagesh Sanghavi, Eliot Gerstner
5.1 Introduction..................................................................................107
5.2 Problem definition and solution approach...................................109
5.3 Optimization methodology ..........................................................110
5.4 Experimental results ....................................................................113
5.5 Summary......................................................................................119
6. Linear Programming for Gate Sizing 121
6.1 Introduction..................................................................................121
6.2 Overview of TILOS gate sizing...................................................124
6.3 Linear programming formulation ................................................126
6.4 Optimization flow........................................................................137
6.5 Comparison of gate sizing results................................................140
6.6 Computational runtime ................................................................143
6.7 Summary......................................................................................147
7. Linear Programming for Multi-Vth and Multi-Vdd Assignment 151
7.1 Introduction..................................................................................151
7.2 Voltage level restoration for multi-Vdd ......................................155
7.3 Previous multi-Vdd and multi-Vth optimization research ..........156
7.4 Optimizing with multiple supply and threshold voltages............160
7.5 Comparison of multi-Vdd and multi-Vth results ........................167
7.6 Analysis of power savings with multi-Vth and multi-Vdd .........171
7.7 Computational runtimes with multi-Vdd and multi-Vth.............185
7.8 Summary......................................................................................186
8. Power Optimization using Multiple Supply Voltages 189
Sarvesh Kulkarni, Ashish Srivastava,
Dennis Sylvester, David Blaauw
8.1 Introduction..................................................................................189
8.2 Overview of CVS and ECVS ......................................................192
8.3
8.4 Power savings with CVS and GECVS ........................................199
8.5 Gate sizing and dual-Vth assignment ..........................................201
8.6 Power savings with VVS and GVS.............................................211
8.7 Summary......................................................................................214
9. Placement for Power Optimization 219
Ameya R. Agnihotri, Satoshi Ono, Patrick H. Madden
9.1 Introduction..................................................................................219
9.2 Placement basics..........................................................................221
9.3 Physical synthesis ........................................................................226
9.4 Multiple supply voltage placement .............................................239
9.5 State of the art..............................................................................242
9.6 Summary......................................................................................246
10. Power Gating Design Automation 251
Jerry Frenkil, Srini Venkatraman
10.1 Introduction..................................................................................251
10.2 Leakage control techniques .........................................................252
10.3 Power gating design issues ..........................................................255
10.4 Coolpower design automation .....................................................262
10.5 Application flows.........................................................................269
10.6 Results..........................................................................................272
10.7 Future work..................................................................................277
10.8 Summary......................................................................................278
281
Barry Pangrle, Srikanth Jadcherla
11.1 Introduction..................................................................................281
11.2 Multiple voltage definitions and scenarios..................................283
11.3 Design examples..........................................................................290
11.4 Summary......................................................................................297
12. Winning the Power Struggle in an Uncertain Era 299
Murari Mani, Michael Orshansky
12.1 Introduction..................................................................................299
12.2 Process variability and its impact on power................................300
12.3 Parametric yield estimation .........................................................303
12.4 Optimization techniques for yield: an overview .........................305
12.5 Efficient statistical parametric yield maximization.....................308
12.6 Summary......................................................................................319
DESIGN EXAMPLES
13. Pushing ASIC Performance in a Power Envelope 323
Leon Stok, Ruchir Puri, Subhrajit Bhattacharya, John Cohn,
Dennis Sylvester, Ashish Srivastava, Sarvesh Kulkarni
13.1 Introduction..................................................................................324
13.2 Power-performance trade-off with multi-Vdd and multi-Vth.....324
13.3 Design issues in multi-Vdd ASICs..............................................332
13.4 Case study ....................................................................................344
13.5 Summary......................................................................................353
14. Low Power ARM 1136JF-S Design 357
George Kuo, Anand Iyer
14.1 Introduction..................................................................................357
14.2 Project objective ..........................................................................358
14.3 Key decisions and implemenations .............................................362
14.4 Results..........................................................................................377
14.5 Summary......................................................................................381
发表于 2010-1-2 15:05:54 | 显示全部楼层
After download, maybe you must add the ".rar" extension to file names due to extension missing. And then unpack them to get pdf file. Enjoy!
发表于 2010-1-5 16:02:37 | 显示全部楼层
Verification
发表于 2010-1-5 16:18:36 | 显示全部楼层
学习 1# benemale
发表于 2010-1-5 20:36:26 | 显示全部楼层
低功耗应该和工艺关系也是密切相关的,不知书里提了没有
下来看看!
GMT+8, 2025-10-20 14:37 , Processed in 0.017283 second(s), 3 queries , Gzip On, Redis On.
