查看: 2843|回复: 1
[讨论] UART : 减少资源的使用
发表于 2017-12-10 20:19:27 | 显示全部楼层 |阅读模式
谁有办法比原来的编码方法更进一步减少资源的使用吗?
http://hamsterworks.co.nz/mediawiki/index.php/TinyTx
use IEEE.STD_LOGIC_1164.ALL;
entity tiny_rs232_tx is
    Port ( clk         : in  STD_LOGIC;
       bit_tick    : in  STD_LOGIC;
       data        : in  STD_LOGIC_VECTOR(7 downto 0);
       data_enable : in  STD_LOGIC;
       tx          : out STD_LOGIC := '1';
       busy        : out STD_LOGIC );
end tiny_rs232_tx;
architecture Behavioral of tiny_rs232_tx is
signal shift_reg  : std_logic_vector(9 downto 0) := (others => '1');
signal i_busy     : std_logic;
begin
    busy <= i_busy;
    with shift_reg select i_busy <= '0' when "0000000000", '1' when others;
clk_proc: process(clk)
begin
    if rising_edge(clk) then
        if i_busy = '0' and data_enable = '1' then
            shift_reg <= '1' & data & '0';
        end if;
        if bit_tick = '1' then
            if i_busy = '1' then
                tx <= shift_reg(0);
                shift_reg <= '0' & shift_reg(9 downto 1);
            end if;
        end if;
    end if;
end process;
end Behavioral;[/code]
发表于 2017-12-22 16:10:12 | 显示全部楼层
This is small module, do not waste your time just for improving some lines of code =))
GMT+8, 2025-11-8 05:22 , Processed in 0.015080 second(s), 3 queries , Gzip On, Redis On.
