查看: 15723|回复: 10
calibre license问题求助. Cannot connect to license server system
发表于 2014-11-29 22:22:33 | 显示全部楼层 |阅读模式
calibre license问题
安装的是x86_cal_2011.2_34.26, 参见论坛里的版本http://bbs.eetop.cn/thread-311773-1-1.html
完全安装,也patch了, license也是一步步安照上面做的。
calibre -lvs xxxx, 报错
//  Error: The following products could not be licensed sufficiently:
//  Error: - LVS (Flat)
lmstat -a, 报错
-----------------------------------------lmstat - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved.
Flexible License Manager status on Sat 11/29/2014 21:57
License server status: 1818@x201
    License file(s) on x201: /mentor/license/license.dat::
lmgrd is not running: Cannot connect to license server system. (-15,570:115 "Operation now in progress")
lmdown -c /mentor/license/license.dat, 报错
lmdown - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved.
Shutdown failed: Cannot connect to license server system. (-15,570:115 "Operation now in progress")
环境设置如下:
setenv MGC_HOME     /mentor/calibre/x86_cal_2011.2_34.26
setenv CALIBRE_HOME /mentor/calibre/x86_cal_2011.2_34.26
set path = ( /mentor/calibre/x86_cal_2011.2_34.26/bin $path )
setenv MGLS_LICENSE_FILE /mentor/license/license.dat
setenv LM_LICENSE_FILE /mentor/license/license.dat
网卡信息:ifconfig eth0
eth0      Link encap:Ethernet  HWaddr F0: DE:F1:0F:7A:05
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
          Interrupt:169 Memory:f2500000-f2520000
网卡= Intel(R) 82577LM Gigabit Network Connection
系统= RHEL5.4
当时装系统的时候网卡驱动有问题,费了点功夫,后来装了e1000e-2.5.4.tar.gz
感觉可能是以下两个原因,但不知道如何处理
1. license 没破解好.
我已经试了论坛上各个MentorKG的版本,同时也包括“-f -n -all -maxlen -1 ”等命令
2. 网卡驱动或者设置没弄好,网上找到个类似问题的,但他是安装到XP系统里的
http://www.cnblogs.com/3echo/archive/2007/09/12/890783.html
我看到论坛上有两个兄弟也有类似的问题
http://bbs.eetop.cn/thread-304500-1-1.html
http://bbs.eetop.cn/thread-259113-1-1.html
期待大神出手相助~~
发表于 2014-12-1 17:04:16 | 显示全部楼层
回复 1# spraying
看来你的版权服务器及不能被启动,也不能被关闭,应该是连接服务器设置的问题。先看一下你的版权文件的头两行是啥样的。
发表于 2014-12-1 17:10:53 | 显示全部楼层
努力挣信元,下载资料!
发表于 2014-12-1 19:31:20 | 显示全部楼层
好资料,看看!
发表于 2015-11-29 16:13:40 | 显示全部楼层
我也与到了同样的问题
发表于 2016-1-4 00:04:10 | 显示全部楼层
有解决了吗?也遇到了,求解呢。
发表于 2016-4-11 16:46:13 | 显示全部楼层
真的要吐血了,之前使用论坛上的MentorKG2008 装过好几次都没问题!
现在,也遇到这个问题了试了无数次遍了,hostname、etc/hosts、etc/sysconfig/network试了无数遍了就是不行!
而且,发现应该不是hostname的问题,因为如果不一致,lmgrd就不能启动,会报另外的错!!
发表于 2016-4-11 16:47:58 | 显示全部楼层
神奇的是,为什么关闭network后,还是提示相同的错误!网络都已经关了,他访问到哪里了?
发表于 2016-4-12 16:39:35 | 显示全部楼层
可以手动挂载一下   看看会不会提示有lib没有装上
发表于 2018-1-15 09:53:57 | 显示全部楼层
[quote][/quote]
回复 支持 0 反对 1
GMT+8, 2025-12-23 20:57 , Processed in 0.022108 second(s), 5 queries , Gzip On, Redis On.
