查看: 31275|回复: 106
[原创] 最新版,A Practical Guide to Low-Power Design - User experience with CPF
发表于 2014-10-15 10:26:22 | 显示全部楼层 |阅读模式
最新的,比论坛里的要新。
Foreword
Preface
Acknowledgements
References and Bibliography
Sect.1 - 2
Sect.1 - 3
Sect.1 - 4
Sect.1 - 6
Low-Power Links
     Power Forward Initiative
     Cadence Low-Power Links
Sect.1 - 9
Sect.1 - 10
Sect.1 - 10
CPF Terminology Glossary
     Design Objects
     CPF Objects
Sect.1 - 12
Sect.1 - 12
Sect.1 - 12
Special Library Cells for Power Management
Sect.1 - 14
Introduction to Low Power
     Low Power Today
     Power Management
     Complete Low-Power RTL-to-GDSII Flow Using CPF
     A Holistic Approach to Low-Power Intent
     Verification of Low-Power Intent with CPF
     Power Intent Validation
     Low-Power Verification
     CPF Verification Summary
Sect.1 - 16
Sect.1 - 16
Sect.1 - 18
Sect.1 - 31
Sect.1 - 37
Sect.1 - 40
Sect.1 - 40
Sect.1 - 42
Sect.1 - 57
Front-End Design with CPF
     Architectural Exploration
     Synthesis Low-Power Optimization
     Automated Power Reduction in Synthesis
     CPF-Powered Reduction in Synthesis
     Simulation for Power Estimation
     CPF Synthesis Summary
Sect.1 - 60
Sect.1 - 60
Sect.1 - 62
Sect.1 - 64
Sect.1 - 69
Sect.1 - 79
Sect.1 - 82
Power-Aware Design for Test (DFT)
     Power Domain-Aware DFT
     Power-Aware Test
     CPF Test Summary
Sect.1 - 84
Sect.1 - 84
Sect.1 - 85
Sect.1 - 88
Low-Power Implementation with CPF
     Introduction to Low-Power Implementation
     Gate-Level Optimization in Power-Aware Physical Synthesis
     Clock Gating in Power-Aware Physical Synthesis
     Multi-Vth Optimization in Power-Aware Physical Synthesis
     Multiple Supply Voltage (MSV) in Power-Aware Physical Synthesis
     Power Shut-Off (PSO) in Power-Aware Physical Synthesis
     Dynamic Voltage/Frequency Scaling (DVFS) Implementation
     Substrate Biasing Implementation
     Diffusion Biasing
     CPF Implementation Summary
Sect.1 - 90
Sect.1 - 90
Sect.1 - 93
Sect.1 - 93
Sect.1 - 94
Sect.1 - 95
Sect.1 - 97
Sect.1 - 104
Sect.1 - 105
Sect.1 - 108
Sect.1 - 109
ARC Energy PRO: Technology for Active Power Management
     Overview of ARC Energy PRO
     The Power Struggle
     Designing Low-Power Solutions
     Project Subsystem: ARC CPU with Co-Processor
     Conclusion
Sect.2 - 2
Sect.2 - 2
Sect.2 - 2
Sect.2 - 2
Sect.2 - 5
Sect.2 - 8
NEC Electronics: Integrating Power Awareness in SoC Design with CPF
     NEC Electronics and CPF
     Why Low Power?
     Comprehensive Approach to Low Power
     Example of Mobile Phone System SoC
     NEC Electronics CPF Proof-Point Project: NEC-PPP
     Summary
Sect.3 - 2
Sect.3 - 3
Sect.3 - 4
Sect.3 - 6
Sect.3 - 7
Sect.3 - 11
Sect.3 - 18
Fujitsu: CPF in the Low-Power Design Reference Flow
     Fujitsu and CPF
     Low-Power Design Techniques Used by Fujitsu
     Low-Power Test Chip Developed with CPF
     Low-Power Design Flow with CPF
     Review of Low-Power Test Chip Design
     Fujitsu Reference Design Flow 3.0: Low Power with CPF
     Fujitsu's CPF Low-Power RDF Methodology
     Summary
Sect.4 - 2
Sect.4 - 4
Sect.4 - 5
Sect.4 - 6
Sect.4 - 7
Sect.4 - 8
Sect.4 - 9
Sect.4 -14
Sect.4 -14
NXP User Experience: Complex SoC Implementation with CPF
     Low Power is Critical to NXP
     CPF in Action on a Complex SoC Platform
     Power Network Intent
     Hierarchical Support for IP and Design Reuse
     Scalable Implementation
     DFT Impact
     CPF-Based Results
Sect.5 - 2
Sect.5 - 4
Sect.5 - 7
Sect.5 - 8
Sect.5 - 12
Sect.5 - 13
Sect.5 - 17
Sect.5 - 18
Freescale: Wireless Low-Power Design and Verification with CPF
     Business Implications of Power
     Wireless Carriers and Power
     Phone Power and Energy
     Active Power Challenge and Design Techniques
     Low-Power Design Methodology and CPF
     Mobile Application Power Reduction Results
     Summary
Sect.6 - 2
Sect.6 - 2
Sect.6 - 3
Sect.6 - 3
Sect.6 - 10
Sect.6 - 11
Sect.6 - 14
Sect.6 - 15
TSMC: Advanced Design for Low Power at 65nm and Below
     TSMC 65nm Low-Power Process
     CPF: The Low-Power Standard
     The TSMC Proof-Point Project
     CPF-Based TSMC Reference Flow 9.0.
     TSMC Low-Power Library: CPF Compliant
     Summary
Sect.7 - 2
Sect.7 - 3
Sect.7 - 3
Sect.7 - 3
Sect.7 - 5
Sect.7 -9
Sect.7 - 20
Sect.7 - 21
ARM: 1176 IEM Reference Methodology
     Introduction
     ARM-Cadence Implementation Reference Methodologies
     ARM1176 Processor
     ARM1176JZF-S Low-Power Reference Methodology
     Conclusion
Sect.8 - 2
Sect.8 - 2
Sect.8 - 3
Sect.8 - 4
Sect.8 - 8
Sect.8 - 26
Faraday: CPF-Based Low-Power Design Methodology for Platform-Based SoCs
     Faraday Design Services and Low-Power Design
     Introduction
     Faraday CPF Flow
     Faraday So Compiler CPF-Enabled Platform-Based Design for Low-Power
     A Low-Power Platform-Based Design Example
     Faraday CPF Low-Power SoCompiler Design Methodology Summary
Sect.9 - 2
Sect.9 - 2
Sect.9 - 3
Sect.9 - 4
Sect.9 - 6
Sect.9 - 17
Sect.9 - 23
Sequence Design: Early Power Analysis with CPF
     Design for Power
     Nano CPU Design Overview
     Conclusions
Sect.10 - 2
Sect.10 - 2
Sect.10 - 7
Sect.10 - 11
ARM Cortex iRM: CPF-Driven Low-Power Functionality in a High-Performance Design Flow
     ARM and Cadence Collaboration
     iRM Flow Setups: Adding Low-Power Functionality to a High-Performance Design Flow
     Other Low-Power Functionality Additions to a High-Performance Design Flow
     Conclusions and Availability of ARM/Cadence iRMs
Sect.11 - 2
Sect.11 - 2
Sect.11 - 5
Sect.11 - 16
Sect.11 - 19
When Do You Know You Have Saved Enough Power?
     Impact of Low-Power Design
     Power Dissipation
     Static Power Optimization
     Dynamic Power Optimization
     ARM Intelligent Energy Manager™(IEM)
     Power Savings in Multicore Processors
     Conclusions
Sect.12 - 2
Sect.12 - 2
Sect.12 - 3
Sect.12 - 3
Sect.12 - 5
Sect.12 - 7
Sect.12 - 11
Sect.12 - 14
Sect.12 - 16
AMD: Power Gating in a High-Performance GPU
     AMD and Low Power
     Front-End Low-Power Logical Design/Verification Flow and Methodology
     Back-End Low-Power Physical Design/Verification Flow and Methodology
     CPF and Results
     Summary of Results
Sect.13 - 2
Sect.13 - 2
Sect.13 - 9
Sect.13 - 14
Sect.13 - 19
Sect.13 - 22
ARM 1176-JZFS CPU-Based Low-Power Subsystem:
Methodology to Reduce Electrical and Functional Failure in a Low-Power Design
     Abstract
     Overview of Ulterior Project
     Ulterior Implementation
     Assembly and Packaging
     Ulterior Implementation Results
Sect.14 - 2
Sect.14 - 2
Sect.14 - 2
Sect.14 - 11
Sect.14 - 22
Sect.14 - 23
Sonics: CPF Flow for Highly-Configurable On-Chip Network IP
     Overview
     Sonic Power Management Features
     CPF Generation and Automation
     Sample SoC Design
     Sonics CPF-based Low-Power Flow
     Low-Power Reference Flow and Tools
     Conclusion
Sect.15 - 2
Sect.15 - 2
Sect.15 - 4
Sect.15 - 5
Sect.15 - 6
Sect.15 - 7
Sect.15 - 12
Sect.15 - 14
Virage Logic: Minimizing Design Complexity with Power-Optimized Physical IP
     Virage Logic抯 IP Portfolio
     Economics of Battery Life
     Economics of IC Cooling
     Low Power Design Solutions
     Virage Logic Power-Optimization Kit: Standard Cell Set
     Standard Cell in the Power Optimization Kit
     Using Library CPF for Level Shifters, Retention Flops and Power Switches
     40nm SiWare Memory Performance/Power Tradeoffs for Bank and Column Mux
     Summary
Sect.16 - 2
Sect.16 - 2
Sect.16 - 2
Sect.16 - 3
Sect.16 - 4
Sect.16 - 5
Sect.16 - 5
Sect.16 - 10
Sect.16 - 12
Sect.16 - 19
发表于 2014-10-15 12:56:58 | 显示全部楼层
where
 楼主| 发表于 2014-10-15 13:39:59 | 显示全部楼层
LowPowerGuide09232009_0.zip (4.57 MB , 下载次数: 1295 ) LowPowerGuide09232009_1.zip (13.42 MB , 下载次数: 1784 )
发表于 2014-10-17 09:02:26 | 显示全部楼层
谢谢分享!
发表于 2014-10-22 21:18:54 | 显示全部楼层
下来看看
发表于 2014-10-26 20:02:16 | 显示全部楼层
好大的附件啊。
发表于 2014-10-28 19:08:48 | 显示全部楼层
这个pdf好乱
发表于 2014-11-8 19:07:17 | 显示全部楼层
好大的附件啊。
发表于 2014-11-9 11:46:28 | 显示全部楼层
tool or principle
发表于 2014-11-11 13:45:08 | 显示全部楼层
谢谢楼主分享。
GMT+8, 2025-12-22 09:43 , Processed in 0.022824 second(s), 6 queries , Gzip On, Redis On.
