查看: 26422|回复: 50
[其它] Agilent GoldenGate RFIC Simulation Software 2013.10 - 4.8.3 + FIX
发表于 2014-4-27 06:33:31 | 显示全部楼层 |阅读模式
i have uploaded Agilent GoldenGate RFIC Simulation Software  2013.10 - 4.8.3 + FIX in this page
http://bbs.eetop.cn/viewthread.php?tid=443500&page=1&extra=#pid8137969
install steps
1. Install GoldenGate 2013.10 - 4.8.3
    tar xvzf GoldenGate-201310-4-8-3.tar.gz -C /opt (or your path)
2. Copy over the patched files on the install directory.
3. Open the license file and replace 000000000000 with your host_id.
4. Create the necessary variables in your .bashrc or equivalent:
    export CDS_LOAD_ENV=CSF
    export XPEDION=/opt/GoldenGate-201310-4-8-2
    export GOLDENGATE_LICENSE_FILE=$XPEDION/license.lic
    export HPEESOF_DIR=$XPEDION
    export XPEDION_CADENCE_VERSION=616-64b
    export PATH=$XPEDION/bin:$PATH
5. if you have ADS, change "export HPEESOF_DIR=$XPEDION" to "export HPEESOF_DIR=<ADS Path>"
    and add this line to bashrc
    export PATH=$HPEESOF_DIR/bin:$PATH
6. Launch the license manager:
    $XPEDION/Licensing/2013.09/linux_x86_64/bin/lmgrd -c $GOLDENGATE_LICENSE_FILE
7. In your Cadence installation hierarchy, edit $CDS_INST_DIR/share/cdssetup/setup.loc
   and add these two lines at the end:
    $HPEESOF_DIR/idf/ads_site
    $XPEDION/aa/$XPEDION_CADENCE_VERSION
8. Before launching Virtuoso, execute this in your $HOME directory:
    $XPEDION/aa/user_install.sh
9. Launch Cadence Virtuoso:
    virtuoso &
NOTE:
1- you can use spectre tech file for simulation with goldengate :)
2- if you want to use momentum in virtuoso you must install linux version of ADS
    you can download ADS 2014.1 from agilent site and crack with
    http://bbs.eetop.cn/viewthread.php?tid=441969&
    but if your ADS license.lic file is not accepted after checking.  use GoldenGate license.lic without any problem
发表于 2014-4-27 11:17:19 | 显示全部楼层
goooooooooooooooooooooooooooooooooooooood
发表于 2014-4-27 11:31:01 | 显示全部楼层
发表于 2014-4-27 11:47:06 | 显示全部楼层
gooooooooooooooooooooooooooooood
发表于 2014-5-6 08:09:55 | 显示全部楼层
求问,这一句
是每次都要起动吗?
或只在安装时启动一次?
发表于 2014-5-7 06:10:55 | 显示全部楼层
Good job!
发表于 2014-5-7 11:07:16 | 显示全部楼层
我會嘗試。
发表于 2014-5-7 14:45:45 | 显示全部楼层
已经验证,这个工具99%没问题。
只是不能调用,ADS201401的图显功能?只能在IC616的环境中display
求解答??
好像是ADS的问题
发表于 2014-5-13 01:44:19 | 显示全部楼层
再求Agilent goldengate中ADS Data Display起不来
的答案?
并老提示:
Loading alvs.cxt
# /home/agilent/ADS2014_01/bin/rfdeIpcBoot: line 17: .: vis-bootscript.sh: file not found
# /home/agilent/ADS2014_01/bin/rfdeIpcBoot: line 43: hpeesofemx: command not found
但是到ADS安装位置,vis-bootscript.sh是在那里的!
发表于 2014-5-14 03:42:39 | 显示全部楼层
高手,多谢多谢!!!
GMT+8, 2025-12-15 18:51 , Processed in 0.022880 second(s), 4 queries , Gzip On, Redis On.
