查看: 18823|回复: 18
[求助] hold_time violation?
发表于 2010-7-25 13:33:54 | 显示全部楼层 |阅读模式
大家好,我用DC对我的设计逻辑综合后,在modelsim中进行后仿真。我先对某个路径进行时序检查,得到下面结果:
dc_shell-t> report_timing -delay min -to ref_frame_array_u/w_addr_reg_9_/D
Report : timing
        -path full
        -delay min
        -max_paths 1
Design : ME_and_MC
Version: V-2004.06-SP2
Date   : Sun Jul 25 12:51:16 2010
# A fanout number of 1000 was used for high fanout net computations.
Operating Conditions: typical   Library: typical
Wire Load Model Mode: top
  Startpoint: ref_frame_array_u/w_addr_reg_9_
              (rising edge-triggered flip-flop clocked by clk)
  Endpoint: ref_frame_array_u/w_addr_reg_9_
  Path Group: clk
  Path Type: min
  Des/Clust/Port     Wire Load Model       Library
  ME_and_MC          tsmc18_wl40           typical
  Point                                                   Incr       Path
  clock clk (rise edge)                                   0.00       0.00
  clock network delay (ideal)                             0.00       0.00
  ref_frame_array_u/w_addr_reg_9_/CK (DFFRX1)             0.00 #     0.00 r
  ref_frame_array_u/w_addr_reg_9_/Q (DFFRX1)              0.55       0.55 f
  ref_frame_array_u/add_27/A[9] (ref_frame_array_DW01_inc_13_0)
                                                          0.00       0.55 f
  ref_frame_array_u/add_27/U1_1_9/S (ADDHXL)              0.40       0.95 f
  ref_frame_array_u/add_27/SUM[9] (ref_frame_array_DW01_inc_13_0)
                                                          0.00       0.95 f
  ref_frame_array_u/U61/Y (AND2X2)                        0.23       1.19 f
  ref_frame_array_u/w_addr_reg_9_/D (DFFRX1)              0.00       1.19 f
  data arrival time                                                  1.19
  clock uncertainty                                       0.10       0.10
  ref_frame_array_u/w_addr_reg_9_/CK (DFFRX1)             0.00       0.10 r
  library hold time                                      -0.06       0.04
  data required time                                                 0.04
  data arrival time                                                 -1.19
  slack (MET)                                                        1.14
此报告显示,这段路径没有hold_time violation。然后,我将.v网表和.sdf文件以及stand_cell的.v文件导入modelsim进行时序仿真,会出现下面的违例报告:
# ** Error: /export/home/st5/h.264/sim/tsmc18.v(7692): $hold( posedge CK &&& (flag == 1):5095 ns, negedge D:5095 ns, 500 ps );
#    Time: 5095 ns  Iteration: 2  Instance: :me_tb:ME_and_MC_u:ref_frame_array_u:w_addr_reg_9_
因此,比较迷惑,现在请教大家,该如何处理这类问题。下面是我从.sdf文件中截取的w_addr_reg_9_的时序信息:
(CELL
  (CELLTYPE "DFFRX1")
  (INSTANCE ref_frame_array_u/w_addr_reg_9_)
  (DELAY
    (ABSOLUTE
    (IOPATH (posedge CK) Q (0.805:0.805:0.805) (0.553:0.553:0.553))
    (IOPATH (negedge RN) Q () (0.460:0.460:0.460))
    (IOPATH (posedge CK) QN (0.771:0.771:0.771) (0.663:0.663:0.663))
    (IOPATH (negedge RN) QN (0.680:0.680:0.680) ())
  (TIMINGCHECK
    (WIDTH (posedge CK) (0.129:0.129:0.129))
    (WIDTH (negedge CK) (0.177:0.177:0.177))
    (SETUP (posedge D) (posedge CK) (0.077:0.077:0.077))
    (SETUP (negedge D) (posedge CK) (0.157:0.160:0.160))
    (HOLD (posedge D) (posedge CK) (-0.058:-0.059:-0.059))
    (HOLD (negedge D) (posedge CK) (-0.055:-0.059:-0.059))
    (SETUP (posedge RN) (posedge CK) (0.058:0.058:0.058))
    (HOLD (posedge RN) (posedge CK) (-0.038:-0.038:-0.038))
    (WIDTH (negedge RN) (0.192:0.192:0.192))
下面是stand_cell的.v文件中DFFRX1的描述:
`timescale 1ns/1ps
`celldefine
module DFFRX1 (Q, QN, D, CK, RN);
output Q, QN;
input  D, CK, RN;
reg NOTIFIER;
supply1 xSN;
  buf   XX0 (xRN, RN);
  buf     IC (clk, CK);
  udp_dff I0 (n0, D, clk, xRN, xSN, NOTIFIER);
  and     I4 (flag, xRN, xSN);
  buf     I1 (Q, n0);
  not     I2 (QN, n0);
  specify
    specparam
    tplh$RN$Q  = 1.0,
    tphl$RN$Q  = 1.0,
    tplh$RN$QN  = 1.0,
    tphl$RN$QN  = 1.0,
    tplh$CK$Q = 1.0,
    tphl$CK$Q = 1.0,
    tplh$CK$QN = 1.0,
    tphl$CK$QN = 1.0,
    tsetup$D$CK = 1.0,
    thold$D$CK = 0.5,
    tsetup$RN$CK    = 1.0,
    thold$RN$CK    = 0.5,
    tminpwl$RN     = 1.0,
    tminpwl$CK    = 1.0,
    tminpwh$CK    = 1.0;
    if (flag)
      (posedge CK *> (Q +: D)) = (tplh$CK$Q,    tphl$CK$Q);
    if (flag)
      (posedge CK *> (QN -: D)) = (tplh$CK$QN,   tphl$CK$QN);
    $setuphold(posedge CK &&& (flag == 1), posedge D, tsetup$D$CK, thold$D$CK, NOTIFIER);
    $setuphold(posedge CK &&& (flag == 1), negedge D, tsetup$D$CK, thold$D$CK, NOTIFIER);
      (negedge RN *> (Q +: 1'b0)) = (tphl$RN$Q);
      (negedge RN *> (QN -: 1'b0)) = (tplh$RN$QN);
    $setuphold(posedge CK, posedge RN, tsetup$RN$CK, thold$RN$CK, NOTIFIER);
    $width(negedge RN, tminpwl$RN, 0, NOTIFIER);
    $width(negedge CK &&& (flag == 1), tminpwl$CK, 0, NOTIFIER);
    $width(posedge CK &&& (flag == 1), tminpwh$CK, 0, NOTIFIER);
   endspecify
endmodule // DFFRX1
`endcelldefine
大家看看,该如何处理这里问题啊,小弟先谢谢各位了。
发表于 2010-7-25 16:18:04 | 显示全部楼层
好像记得vcs有一个 “识别负值的选项”, 若不加那个选项仿真,负值的setup和hold check会报error。 建议你vcs -help一下
发表于 2010-7-26 08:45:01 | 显示全部楼层
怎么会有负的hold和setup,第一次接触到啊
发表于 2010-7-26 09:46:42 | 显示全部楼层
setup都是正的,hold是有可能是负的,意思是说在触发沿到来前,从触发器的数据已经得到保证。具体可以在网上搜下这方面的资料,我以前看到过说这个的原理,但是现在找不到了。
发表于 2010-7-26 10:42:35 | 显示全部楼层
holdtime是负的这很简单,你把flop里面的clock加缓冲器延迟一段时间,那么holdtime就可能是负的,但是setup+hold必须为正。
关于2#所说的,一般在vcs里面需要加 +neg_tchk,但是好像modelsim里面一般默认是能够检查负的holdtime的,所以X6J6P6 最好去确认一下。
另外,X6J6P6你设置的verilog仿真时间精度是多少?
 楼主| 发表于 2010-7-26 11:09:36 | 显示全部楼层
大家好,hold_time 是负的,是有可能的,至于yohuang兄说的时间精度,我的定义如下:
`timescale 1ns/1ns
其实,我认为,我的综合后的后仿真不过,可能是我在综合时的约束文件中将时钟信号和复位信号定义为ideal_network了。
发表于 2010-7-26 11:18:00 | 显示全部楼层
你的时间精度设置有问题!
把精度改成10ps 或者 1ps, 看看结果!
 楼主| 发表于 2010-7-26 12:18:14 | 显示全部楼层
yohuang兄,你好,我把精度改成:
`timescale 1ns/1ps
好像还是不行啊。
发表于 2010-7-26 12:39:09 | 显示全部楼层
有没有MSN? 这么交流太费劲
 楼主| 发表于 2010-7-26 13:39:05 | 显示全部楼层
有,yohuang兄,说你的账号吧。
GMT+8, 2025-12-16 02:07 , Processed in 0.066167 second(s), 5 queries , Gzip On, Redis On.
